0 Members and 215 Guests are viewing this topic.
Hoppy
Quote from: Zeitmaschine on March 26, 2013, 03:25:15 PM
On page 1057 and here: Power meter tricks (09-07-11, 01:50 AM)
Thanks. This occurred on the old mechanical meters with energy reverse detection. The poor PF on welders was the cause. No free lunch with the new smart meters!
Zeitmaschine
Quote from: Hel on March 26, 2013, 03:33:58 PM
I don't see how shaking or stimulating the natural media could
give us something back... I mean, I don't want to exclude this possibility but we lack any credible theory to start with.
Any other way to use the existing field won't give you any free energy.
The credible theory to start with is the (grounded) Faraday cage which shields the electric field. No electric field inside but an inexhaustible field outside, hence there occurs a difference. Now let the electric field from the outside flow into the empty cage due to this difference. This flow will create energy which can be used to prevent the inflowing electric field from filling up the cage by converting it constantly into an electric current (pumping) which then can be used to drive something like an incandescent light bulb.
It's all plain and simple in theory, but I haven't figured out yet which part of the (parametric) circuit should be in the Faraday cage and which part should be connect to an antenna (residing outside the cage). And maybe in the cage there has to be something special but however not so special at all because everyone should be able to make it (with a sledgehammer).
Quote from: Hoppy on March 26, 2013, 03:52:16 PM
Anyway Stepanov's power meters are looking very smart but nevertheless he gets free lunch on regularly basis. ;D
Quote from: forest on March 26, 2013, 03:39:16 PM
Tesla article ? Of course the one and only where he had given his visionary thoughts/tips about future
And there is a hole in the lake? ???
BTW: What could happen if there were a Faraday cage within a Faraday cage so both cages are the two plates of one capacitor? Doesn't the silver cylinders of the Testatika looking that way? A Faraday cage and a capacitor in one piece? Nice idea, who wants to try it?
Grumage
Hello to all,
Re Electricity meters going backwards. As you are all probably aware my background was Electrical engineering with one of the local supply Board's, as they were then known. I worked in a number of different departments covering HV testing, Protection maintenance, test equipment etc. To the point... There was a black box that was alledgedly developed in Liverpool England. You had some leads coming out with crock clips that you hung onto the bare meter tails. This black box was able to cause reverse rotation of the old disc meters. While it was doing this they got really hot (black box) and caused a number of fires!! They used, if I can remember correctly a Quadrature transformer. It changes the phase angle so the disc recieved less torque or was even able to reverse it.
Maybe it could be an answer, if looked into. Btw these "Black boxes" were designed to  "Fox" single phase meters in the domestic area. Sold on the black market for £50.00, about 25 years ago.
The Industry got wise and fitted detent springs to stop reversal!
Cheers Grum.
Hoppy
Quote from: Grumage on March 26, 2013, 04:44:17 PM
Hello to all,
Cheers Grum.
I remember that one. Also, a few powerful neo magnets strategically placed also did the trick to stop the mechanical meters and no connections required and much cheaper!
Hoppy
Quote from: Zeitmaschine on March 26, 2013, 04:14:25 PM
Nothing gets in or out  :)
