0 Members and 78 Guests are viewing this topic.
Ahh, thanks, Stefan, for a while there I thought these forums only happened in English and German.
The translation reads like weird Joycian poetry. The weirdest part is I think I understand it.
"Well, I do not know how you MOSFETAMI kolduete (their children's elementary multivibrator will go, and they are better off removed from them, but no price), it is to your ideas for articles, I have to opto-thyristors that stuff in the resonant roar imposed (RESONANCE HERE Best of all, becomes more beautiful). Напруга у мене жесÑ,кая леÑ,ела (если конечно лампочку замениÑ,ÑŒ 2киловаÑ,ным Ñ,еном). Voltage in less rigid flying (unless of course the light bulb to replace 2kilovatnym tenom). Пришлось Ñ,ирисÑ,оры еще круче сÑ,авиÑ,ÑŒ кондеры рвало, 2 Ñ,ранса паралелил на выÑ...од (Переменку Ñ...оÑ,елось, заманчиво ведь)и сжог. Thyristors even steeper had put kondery vomiting, 2 trance paralelil output (Peremenku like tempting it) and szhog. Много я иÑ... на перекосаÑ... спалил. I have a lot of them on the twisting asleep. Ð'ремени у меня к сажелению не много. The time I have to sazheleniyu not much. Ð"о серьезного уровня ... Until a serious level ... довесÑ,и очень сложно. it is very difficult to communicate. ПоэÑ,ому не шиÑ,,руйÑ,есь пишиÑ,е, вываливайÑ,е все. Therefore, it is not encrypted e-mail, tip out all. Ð'се равно Ñ,акие, как Мельниченко милионерами не сÑ,ануÑ,, а бензин и элекÑ,ричесÑ,во им долго покупаÑ,ÑŒ придеÑ,ся. All the same, such as Melnychenko milionerami will not, as gasoline and electricity will have to buy them a long time. Ð' месÑ,е мы сможем, а одному дорого и долго. At the place we can, as a costly and long. Ð"а чуÑ,ÑŒ не забыл возьмиÑ,е на вооружение сÑ...емку регуляÑ,ора напряжения оÑ, любого пылесоса, эÑ,о уникальная шÑ,ука снимаеÑ, всю прибавку с резонанса. Yes I almost forgot to take shemku by the voltage regulator of any vacuum cleaner is a unique piece takes the entire increase in the resonance. Любой Ñ,ранс и каÑ,ушку можно загнаÑ,ÑŒ в резонанс, но очень важно его не глушиÑ,ÑŒ, а снимаÑ,ÑŒ(Ñ,ипа 4 полюсника Мельниченки) Any trance and coil can be forced at resonance, but it is very important it does not stun and remove "
hartiberlin
This is exactly what I mean !
Tesla used DISPLACEMENT CURRENT transmission in the RF range.
See the receiver in the attached picture at the very upper right side.
There he uses just one ground connection with a coil ( can be a transformer to couple
a load at the seondary) and an airdisc as the capacitor.
In this series LC circuit the displacement current is highest, when in resonance with the
incoming ground displacement current.
You can study this further at:
http://www.tfcbooks.com/tesla/1919-05-00.htm
hartiberlin
P.S. the transmitter can also be the hundreds of lightnings hitting the earth each second
around the world.
As the earth has only a resistance of a few ohms, these displacement currents can travel very
far without too many losses...
So the question is, what is the frequency Kapanadze is tuning into ?
Is it the 50 Hz grid frequency or is he using other displacement current frequencies
more in the Khz or Mhz range ?
HeairBear
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
hartiberlin
Quote from: HeairBear on July 03, 2009, 09:43:22 PM
A wideband crystal radio perhaps?
No, it is a displacement current receiver working probably on 50 Hz.
The art is in the syncing into resonance on the existing 50 Hz ground currents
with less energy needed than he is able to extract.
