0 Members and 521 Guests are viewing this topic.
captainkt
@hoppy, problem with diagram is that only one single earth wire went to green box device, this is clearly visible. Also man would need to juggle wires or he would electrocute himself or certainly be liable for nasty burns to hands or feet. Lots of people watching also.
Keith
jbignes5
Quote from: Hoppy on March 27, 2013, 04:17:53 AM
I just had the distinct impression that you thought that this was how TK may have achieved power transfer from the environment to his lamp array. Given that this was clearly not the method used, how do you think TK did it with no user supplied input energy and just a 9V battery to start-up his devices? All this Tesla tech is all very good but we need to focus on how TK did it so simply that it it would make one laugh  :)
My distinct impression is that you are making a joke of this.
If you want to learn how TK did it then I suggest you learn from TK source. CLEARLY TK said it was all learned from Tesla's ideas and experiments. You want to learn TK's ways then you better learn Tesla's ways. TK said it was all on the Internet, Available freely.
But then again why not keep making jokes and adding nothing to this topic of value.
So did anyone watch the videos I posted? Anyone see what I was talking about?
lets look at it like this. We live in the dielectric of a humongous capacitor. When you look at all the information on the net about capacitors you learn there is very interesting effects going on inside of that capacitor. Especially the organized lineup of charges. Now something must be lining up in our dielectric besides charges. Since the electric field is that something we know its direction and what the plates are. It should be simple enough to use this information to cause a flow then harness that flow in between the plates.
Hoppy
Quote from: captainkt on March 27, 2013, 08:42:31 AM
Keith
The cable termination in the green box was not visible. The other end likewise connected to the 'hot' wire coming from the transformer and to the 'earth' coming from the water pipe. Given that the transformer was putting out low voltage (under 50V), no burns or electrocution would have been suffered with just minimal insulation. The high voltage to run the lamps would have been generated inside the green box and effectively isolated from the low voltage side. These guys are magicians, so no problem with dexterity. The spark gap was probably  just eye candy. How else could there have possibly been a genuine 20A plus measured on the earth cable. I suspect the cable coupling arrangement was quite sophisticated. Its possible that there was a pre-made up and very flexible wire running from the guys hand and down his leg. Terminations could have been made using metal spikes that penetrated the insulation. Yes, lots of people watching but how many were looking carefully at the bearded guy.
The later Aqua2 device was clearly more sophisticated, as the 'earth' connection was as discussed earlier, likely carrying HV and again with two conductors but very much smaller in gauge. As for the Turkish videos, we just do not have enough info to know what really happened.
Grumage
Quote from: captainkt on March 27, 2013, 04:25:39 AM
@grumage, yes I agree with your post and the black boxes but how does my meter and lots of other meters with solar panels go backwards, on as sunny day my meter spins quite fast in reverse. My set up is 4KW on my garage roof ?
Keith
Hello captainkt,
I think Hoppy's link should have explained your post. You have a 4Kw PV set up, on a good day you are probably generating more energy than you are consuming. Voltage on voltage drive coil equal. Current coil sees current in opposite direction, therefore the disc turns in the opposite direction. All I will say is that for goodness sake DON'T tell your supplier :)
Cheers Grum.
PS Try making this one go backwards!!!
Hoppy
Quote from: jbignes5 on March 27, 2013, 11:59:16 AM
Not at all (well maybe a little humour to lighten things up), because so far a conventional circuit explanation along the lines shown by the schematic is IMO the only plausible explanation presented that fits the observations in TK's 'Green Box' video.
