0 Members and 209 Guests are viewing this topic.
guruji
Hi I came across this endless amp maybe those transistors that TK have is this:
stivep
My  Lithuania experiment with ferrite has now explanation- I presented  extraction of energy from  ferrite  of 1 KW at maximum
activated by radio wave or electromagnetic frequency source of miliW
http://www.youtube.com/watch?v=Mk3ku_dBzBM
When you take and compare these two pieces of  information
one with glass tube is giving you confirmation of Colman concept
and Lithuania experiment  with  Ferrite ring gives you example of how electrical energy could be extracted
For me is clear now that non radioactive compound  in the ferrite could be activated as well.
Wesley
NickZ
  Wesley:
  I'm still very interested in your previous yoke core experiments. Why have you not continued to improve on it any further?
  Here is my current set up, able to light Cfls to their normal lumin levels, but only using 12v, and 500mAs, or less.
                                         NickZ
bass
something new
Electrostatic induction, or through the effects of electrification - the redistribution of the charges on the surface of a conductor under the influence of an external electric field.
Sketch here to describe
For example:
1. In the first quarter of the oscillation period of the generator is a positive potential goes on one of the capacitor plates. It is the method of electrostatic induction effect on the second plate capacitor which is beginning to accumulate electrons from the conductor through which the load is connected to the infinite reservoir of electrons Earth. In conductor the electron current flowing through the load.
2. In the second quarter of a positive potential on the first plate of capacitor connected to the generator is reduced, hence the second capacitor plate of the electrons through a wire to the load goes back to the Earth. Again, through the load current flows.
3. In the third quarter of the period of the generator starts increasing negative potential, which again causes the electrostatic induction method with a second capacitor plate to send electrons through the load into the Earth. In the load current flows.
4. In the fourth quarter of a negative potential on the first plate capacitor decreases that causes electrons to return again from the Earth to the load. In the load current is flowing again.
As I understand in this case, the energy source is not taken, as the charges for the first plate capacitor as taken from the source and then return back to the source.
I think this circuit is a current source, rather than a source of stress as we know it.
Will try to determine how the formulas current will flow in the wire through the load, if it is wrong to get better.
Current - quantitative charge passed through the wire cross-section per unit of time
I=Q/t
The capacitance is the ratio of the number of charges on the plate of the capacitor to the potential difference (voltage) across the capacitor
C=Q/U     Q=CU
Substitute in the current value of Q from the second formula and obtain
I=CU/t
In this case, t-this time a quarter of the oscillation period t = T / 4
The period of oscillation is related to the frequency of the so T = 1 / f
Hence t = 1/4f
We substitute this value in the current and obtain I = 4CUf.
Take the original data
C = 15 uF, U = 220 V, f = 2000Hz. It turns out I = 4 * (15/1000000) * 220 * 2000 = 26.4 A.
Almost like Kapanadze. While in theory it turns out that for a large current in the ground wire is not necessary to have a very high voltage and high frequency.
Check almost still can not until winter.
I would appreciate if someone has delivered its opinion.
Grumage
Hello to all,
I really do think I have the answer to the TK device. Two words.. Resonance and Symmetry. And it IS so simple you would laugh! It even incorporates Zeitsmaschine's beloved Faraday cage :)
And to all who scoffed at jbignes5, sorry it is Tesla Tech!! It is basically Tesla's Radiant energy transformer.
Mr forest has been dropping tantalising clues in my direction for weeks now, and yes, I did see your post that you subsequently removed!!
Right, the answer, however the practical side will be a lot more difficult to achieve than the solution!!!
The Primary is a Resonant Tesla coil radiating energy. Now we all know that in any transformer circuit whatever you extract from the secondary it is always reflected back to the Primary. That is effectivley destroying the Symmetry. This is not what we want!! With great thanks to Ganzha and forest, I was able to put the whole thing together.
In order not to destroy the Primary's Symmetry, Tuned secondary coils, ( remember TK's patent notes, First bobbin. Second bobbin.)  placed nearby pick up the Radiant energy and by the use of Zeitmaschine's metal box intensify the current.
As you can see there is nothing new about this, Hubbard, Don Smith The old scientist etc etc.
But as I said earlier the practical will be a tougher challenge all together!!
Watch this again.....  http://youtu.be/r4dP1IF70a8   A solid state Tesla coil with an output spark that looks like a candle flame. I have never achieved any thing that looks like that!!! Could someone persuade him to part with the primary drive's circuit diagram?
Any way I have given you plenty of .308's, start Sniping!!!
To jbignes5, please reconsider your situation, I have found your insight refreshing, and remember " Nill carborundum illegitimo" " Don't let the b______'s grind you down"
Cheers to all Grum.
