0 Members and 463 Guests are viewing this topic.
stivep
Quote from: NickZ on March 31, 2013, 12:08:04 PM
  Wesley:
  I'm still very interested in your previous yoke core experiments. Why have you not continued to improve on it any further?
  Here is my current set up, able to light Cfls to their normal lumin levels, but only using 12v, and 500mAs, or less.
                                         NickZ
The answer was simple
I found side effects of non  described nature
and now everything looks simple
Ferrite ring - Lithuania Experiment is the device that  extract up to 1KW energy activated by frequency or radio frequency.
Colman  patent in my lab is prove of that process to take place.
The secret is
NOT NOT  ENOUGH POWER from transmitter or generator to activate other similar rings
The original Rubin Ferrite Yoke has had  crystalline compound  that reacted from miliwats
Technology is 100% repeatable  as of yesterday.
The only difference with  Lithuania Experiment and Colman is That Colman transmutates   for 70 years
And that is why I as one man who never ask for your support can not do both.
look also  for
Rudolf Ludwig Mössbauer
and
quote:
QuoteArmy Research Lab did betavoltaic testing in 1954 using dissimilar metals. In one device not much larger than a car battery they were successful in achieving a 70 watt output ). As early as 1973, betavoltaics were suggested for use in long-term medical devices such as pacemakers.
or
QuoteBetavoltaics are generators of electrical current, in effect a form of battery, which use energy from a radioactive source emitting beta particles (electrons). A common source used is the hydrogen isotope tritium. Unlike most nuclear power sources, which use nuclear radiation to generate heat, which then is used to generate electricity (thermoelectric and thermionic sources), betavoltaics use a non-thermal conversion process; converting the electron-hole pairs produced by the ionization trail of beta particles traversing a semiconductor
Wesley
x_name41
Quote from: bass on March 31, 2013, 12:58:31 PM
something new
Electrostatic induction, or through the effects of electrification - the redistribution of the charges on the surface of a conductor under the influence of an external electric field.
Sketch here to describe
For example:
1. In the first quarter of the oscillation period of the generator is a positive potential goes on one of the capacitor plates. It is the method of electrostatic induction effect on the second plate capacitor which is beginning to accumulate electrons from the conductor through which the load is connected to the infinite reservoir of electrons Earth. In conductor the electron current flowing through the load.
2. In the second quarter of a positive potential on the first plate of capacitor connected to the generator is reduced, hence the second capacitor plate of the electrons through a wire to the load goes back to the Earth. Again, through the load current flows.
3. In the third quarter of the period of the generator starts increasing negative potential, which again causes the electrostatic induction method with a second capacitor plate to send electrons through the load into the Earth. In the load current flows.
4. In the fourth quarter of a negative potential on the first plate capacitor decreases that causes electrons to return again from the Earth to the load. In the load current is flowing again.
As I understand in this case, the energy source is not taken, as the charges for the first plate capacitor as taken from the source and then return back to the source.
I think this circuit is a current source, rather than a source of stress as we know it.
Will try to determine how the formulas current will flow in the wire through the load, if it is wrong to get better.
Current - quantitative charge passed through the wire cross-section per unit of time
I=Q/t
The capacitance is the ratio of the number of charges on the plate of the capacitor to the potential difference (voltage) across the capacitor
C=Q/U     Q=CU
Substitute in the current value of Q from the second formula and obtain
I=CU/t
In this case, t-this time a quarter of the oscillation period t = T / 4
The period of oscillation is related to the frequency of the so T = 1 / f
Hence t = 1/4f
We substitute this value in the current and obtain I = 4CUf.
Take the original data
C = 15 uF, U = 220 V, f = 2000Hz. It turns out I = 4 * (15/1000000) * 220 * 2000 = 26.4 A.
Almost like Kapanadze. While in theory it turns out that for a large current in the ground wire is not necessary to have a very high voltage and high frequency.
Check almost still can not until winter.
I would appreciate if someone has delivered its opinion.
bass776 for you may be a new but for me it is not since the I had only described everything concerning this method and please i would not like to discuss the with you these things because it you have a distorted thinking and distorted savvy as evidence of the this it is another wrong scheme you have shown!, squirt shitty! (бунак смотан!)
p.s. if you are not bass776 I apologize a lot because this is addressed to the bass776!
bass
Quote from: x_name41 on March 31, 2013, 02:12:12 PM
But your circuits do not work too. Or work?
You academician, to indicate to all what is right and what is wrong?
Let's not point out to each other what to do. Maybe not right and you and I.  :)
And you and I and everyone here put only the principles that we think they're working. But there is not a working copy you or me.
Why do you do not like him (bass776)?
jbignes5
Quote from: x_name41 on March 30, 2013, 03:08:38 PM
Тesla electric car is called "model S" :)
Do you have a link to the model s pierce arrow from 1930? Because There is no such beast that I can find on the Internet.
jbignes5
Quote from: Grumage on March 31, 2013, 02:03:03 PM
Hello to all,
I really do think I have the answer to the TK device. Two words.. Resonance and Symmetry. And it IS so simple you would laugh! It even incorporates Zeitsmaschine's beloved Faraday cage :)
And to all who scoffed at jbignes5, sorry it is Tesla Tech!! It is basically Tesla's Radiant energy transformer.
Mr forest has been dropping tantalising clues in my direction for weeks now, and yes, I did see your post that you subsequently removed!!
Right, the answer, however the practical side will be a lot more difficult to achieve than the solution!!!
The Primary is a Resonant Tesla coil radiating energy. Now we all know that in any transformer circuit whatever you extract from the secondary it is always reflected back to the Primary. That is effectivley destroying the Symmetry. This is not what we want!! With great thanks to Ganzha and forest, I was able to put the whole thing together.
In order not to destroy the Primary's Symmetry, Tuned secondary coils, ( remember TK's patent notes, First bobbin. Second bobbin.)  placed nearby pick up the Radiant energy and by the use of Zeitmaschine's metal box intensify the current.
As you can see there is nothing new about this, Hubbard, Don Smith The old scientist etc etc.
But as I said earlier the practical will be a tougher challenge all together!!
Watch this again.....  http://youtu.be/r4dP1IF70a8   A solid state Tesla coil with an output spark that looks like a candle flame. I have never achieved any thing that looks like that!!! Could someone persuade him to part with the primary drive's circuit diagram?
Any way I have given you plenty of .308's, start Sniping!!!
To jbignes5, please reconsider your situation, I have found your insight refreshing, and remember " Nill carborundum illegitimo" " Don't let the b______'s grind you down"
Cheers to all Grum.
You know, you are right. I don't know sometimes what gets me so down. I have had a very bad few weeks with my health, bad back, and finding my friend dead on his porch two weeks ago.
Although I try to be as accurate as possible when working on this stuff I get confused at the setups and some of the methods used by TK. It is very hard to research the methods from Tesla's writings then come here and put them in line with the devices TK built.
The one fact is that TK said that all of his inventions after the water car was due to Tesla. There is a secret in there and I think I might be on track because of the attacks levied at me. Once I can verify these with actual working devices from my lab it is yet another theory. Since no one seems to want to replicate TK's stuff with the knowledge that Tesla was at the root of it, we will have to wait till I get the lab up and running.
Most of the guys that were doing work got tricked away by the Russian patents and Verpies. I see wasabi/Verpies never really commented on the reasons for derailing wattsup and a few other builders from this thread. I have been watching Verpies and wasabi for quite some time now and I'm starting to see a pattern of derailing a great many threads around here. Of which I almost fell prey to. Oh well.
