0 Members and 233 Guests are viewing this topic.
leo48
QuoteDo you have a link to the model s pierce arrow from 1930? Because There is no such beast that I can find on the Internet.
You view this link...
http://www.overunity.com/6319/tesla-car-and-his-nephew/#.UVnlQ6poFzU
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
jbignes5
I too believe that this guy was or is onto something. It sorta looks like the hand drawn picture I drew a few posts back. On the original tesla coil that he shows first the event coming off of the wire is exactly what we are looking for. It looks like a gaseous emanation under pressure. He then attaches a second coil which is merely a radiator of the radiant energy. The metal plate is the pickup and the other end is free or a virtual ground.
You can see the effect that his hand has on the electric field and the emf meter is a great indication of the fields extent.
The color difference has only to do with the excitation level of the radiant e field. The higher the potential value the brighter and hence whiter it becomes.
This is the exact phenomena I saw with the slayer exciter. The reason the slayer exciter has this gaseous emanation that is blue is because it is to low and too slow. It might also be because they are not using impulse DC but are using a form of pulsed AC. I'm not sure because I haven't gotten to the point of those experiments yet.
This concept is akin to the turkey tent show and the inside one, with  all the shielding. I bet the shielding was put there because the turkey investors wanted a reasonably safe environment to walk the investors through. Even though I believe this stuff goes right through the faraday cage. A faraday cage is only good for heavy magnetic fields and not the electric field. If you put a radio inside of the cage it will still have a hiss in the background and will not pickup the radio statins at all.
I'm gonna work on putting all my ideas and research down in another thread soon. This should clear up this thread for the ones who think this doesn't work. I have to work on the diagrams so that they look better then I can draw ATM.
The one problem I have is my scoliosis is bending my spine where my arm and hand nerves come out of my spine. This is causing me to shake terribly from the compression of those nerves. This is why my drawings look like crap and why I had to give up soldering components to boards anymore. I can still solder somewhat but it doesn't even compare to my skill in soldering when this ailment was not so prominent. Slowly my skills that I have worked on for years and years are degrading into a shaky mess. It is a big part of my frustrations ATM.
Zeitmaschine
Quote from: Grumage on April 01, 2013, 03:15:30 PM
This is truly the first step towards my concept of how the TK device works. More coils and an open topped Faraday cage and who knows maybe a winner :)
And more capacitors. Don't forget the capacitors.
I need urgent an idea what the purpose could be to connect a three-phase capacitor with one wire only via a Differential Circuit Breaker? Could this capacitor perhaps act like an antenna?
And I think this is all about creating a parametric resonance (partially) within a Faraday cage in order to pump the Earth electric field outside the cage into it and converting it thereby into useful energy. Although I also think there could be more than one way to create a parametric oscillation. Hence the confusion.
jbignes5
Quote from: leo48 on April 01, 2013, 03:56:56 PM
Leo48
I know about the car and the story. What I am asking is weather or not Pierce arrow was made in a model s. From what I can tell from 1930 that the Pierce arrow only came in two models A and B. I can not find a model s anywhere even from the literature from the manufacturer.
The car story is what got me onto this quest to find out how Tesla did what he did. I think he used a very small broadcaster and a larger receiver and through resonance of both units increased or magnified the output enough to run the motor. I'll have to put a link up again that I think talks about how he got the varied effects he showed through resonance of both transmitter and receiver. It might be buried in the wireless stuff.
Grumage
Quote from: Zeitmaschine on April 01, 2013, 04:15:25 PM
I need urgend an idea what the purpose could be to connect a three-phase capacitor with one wire only via a Differencial Circuit Breaker? Could this capacitor perhaps act like an antenna?
And I think this is all about creating a parametric resonance (partitially) within a Faraday cage in order to pump the Earth electric field outside the cage into it and converting it thereby into useful energy. Although I also think there could be more than one way to create a parametric oscillation. Hence the confusion.
Dear Zeitmaschine,
Don't worry I will not forget the CAPACITORS but you side stepped my question. Is the primary connected to the grid?
Cheers Grum.
