0 Members and 134 Guests are viewing this topic.
Zeitmaschine
There is a major problem with the Stepanov transformer setup: The lever of the circuit breaker which connects the capacitors is set to off as is seems, or isn't it? How could that be?
The main task of this circuit breaker is to detect an earth current where no earth current should be. Interesting. But why is it set to off? ???
Residual-current device
»Any fault to earth (for example caused by a person touching a live component in the attached appliance) causes some of the current to take a different return path which means there is an imbalance (difference) in the current in the two conductors«
Is this (by chance) the difference which occurs between the bobbins mentioned in the TK patent?
So who can explain to me (simple language preferred) why one connects two capacitors to a transformer via a switched off residual-current device which normally is used to detect an imbalance between the energized conductor and the return neutral conductor (ground)? If those capacitors are not connected and hence not needed during this presentation then why are they shown in close-up in the video?
Could it be that someone has tampered with that breaker so its function serves a completely different purpose now? ::)
Hoppy
Quote from: Zeitmaschine on April 01, 2013, 04:15:25 PM
And more capacitors. Don't forget the capacitors.
I need urgent an idea what the purpose could be to connect a three-phase capacitor with one wire only via a Differential Circuit Breaker? Could this capacitor perhaps act like an antenna?
And I think this is all about creating a parametric resonance (partially) within a Faraday cage in order to pump the Earth electric field outside the cage into it and converting it thereby into useful energy. Although I also think there could be more than one way to create a parametric oscillation. Hence the confusion.
These look like PF correction caps which can be switched in or out of circuit manually. What does this suggest?
The cap with just one wire connected is probably sitting there partially connected but not needed.
Hoppy
Quote from: Hoppy on April 01, 2013, 05:54:57 PM
There is a possible indication of faking in the video associated with the circuit below posted earlier by FreeEnergyInfo.
Further observation reveals that the demonstrator slips up with his three-stage switching sequence and gives the game away. He connects the battery then operates the switch but the lamp fails to light. He then realises that the croc clip is disconnected, so he has to start over by re-connecting the croc clip. The first stage of the sequence is the connection of the croc clip to the earth wire. The second stage is the connection of the battery which operates a hidden relay from current carried by the thin twisted pair of wires. The relay connects a mains neutral to the croc clip lead. The mains live is connected by a thin white wire entering the bottom of the long coil from under the table (seen fairly clearly at the start of the video) which is terminated to coil L3. The third stage is the operation of the switch, which lights the lamp directly from the mains and also provides a DC supply from the secondary winding and bridge rectifier / capacitor. This low voltage supply is used to maintain the relay when the battery is disconnected to give the illusion of self-running.
Given how amateurish this fake is, I'm surprised that FreeEnergyInfo could not have posted a more challenging video on April Fools day. The big question is will his next offering be a fake or the real McCoy.
