0 Members and 328 Guests are viewing this topic.
Zeitmaschine
Quote from: Hoppy on April 02, 2013, 04:55:21 AM
These look like PF correction caps which can be switched in or out of circuit manually. What does this suggest?
It suggests that there is no need for a security (differential) circuit breaker between the capacitors and the transformer box. A simple circuit breaker would have done it also (like that one connected below the two black power meters).
Quote from: stivep on April 02, 2013, 10:57:19 AM
That is what might put in question fact  -what TK  is hiding in his device.
http://www.youtube.com/watch?v=V5jFtrpatrA
And what is Stepanov hiding in his device? ::) ???
On the other hand, a differential circuit breaker (one phase) would also fit nicely into TK's tin can. Just in case this component can do something extraordinary that we are not aware of yet.
Hoppy
Quote from: Zeitmaschine on April 02, 2013, 11:54:40 AM
No problem here as this will protect against a fault condition caused by any one of the caps and it might just have been what he had available. The very fact that the caps can be manually switched in or out suggests that these capacitors are important. Have another think about how PF affects performance and how they can affect power meters  ;D
What do you think a simple circuit breaker hidden in TK's tin can could possibly be important for in terms of device performance? I think you are now clutching at straws  :(
Grumage
Quote from: Hoppy on April 02, 2013, 12:15:30 PM
Hello Hoppy and Zeitmaschine,
You have both sparked a memory for me.... Back in the 80's during the construction of Electric mountain in North Wales the CEGB (central electricity generating board) were carrying out tests on the large earth mat that they had placed under the bottom lake. BTW this was a pump storage system. Our team was involved in looking at how effective the earthing was. The test was done by injecting 3KV @ 49 HZ into the mat and groups of engineers with earth rods and volmeters were sent off to different locations. 49 Hz was chosen so that we could see the the 1Hz Beat frequency. What amazed me was that metal objects in the viscinity were charged up to quite high voltage. But more to the point the in and outgoing cables to the local telephone exchange completely melted, it took more than two weeks to sort out!!
My point. What would be the outcome of having two matching transformers looking at each other one sitting at 50HZ and one at 49HZ? My own thinking it would be like trying to join 2 unsyncronized generators together. Massive circulating current. Could this be a way of creating energy by tapping into the beat?
Just a thought, Cheers Grum.
Zeitmaschine
There could be something inside this earth-leakage circuit-breaker (FI-Schutzschalter) that makes it easy (a simple method according to TK) to keep resonance (with whatsoever, maybe two coils).
Investigating ... :)
x_name41
excuse me can the someone to write the exactly what he says for the material indispensable for conducting of the experiment?, thanks in advance!
http://www.youtube.com/watch?v=hYUa5U_cpH0, I read somewhere that in the alien military industrial complex "Dulce" using electricity for producing of water and maybe this is the principle :)
