0 Members and 46 Guests are viewing this topic.
Zeitmaschine
Quote from: a.king21 on April 03, 2013, 06:09:04 PM
Bedini uses a bridge to harvest the energy.
Energy from which source? The Earth's electric field?
Actually it is easy. The ground and the atmosphere make up an infinitely charged capacitor. But we can only reach the lower ground plate of this capacitor and not the upper atmospheric plate. So we put a 3rd plate between these two plates. What do we get? A smaller but also charged capacitor perhaps?
Imagine two ordinary capacitors connected in series. The two outer plates are charged by a high voltage DC generator. Now what to connect to the middle plate in order to draw energy from the static electric field between the two outer plates? It has to be something that creates an oscillation because capacitors pass AC but block DC signals. Furthermore this oscillation should act like a valve so the energy drawn from this capacitor plate stays in the oscillation circuit and can't flow back into the capacitor.
Is there anything wrong with this simple idea? :D
Farmhand
Quote from: elementSix on April 03, 2013, 07:39:40 PM
Another part of getting a working setup is to slowly raise the voltage.  Don't start out with a high input, you have to slowly raise the voltage.  A delay.
Could someone please Read this patent from Tesla.  I don't know if it pertains to this subject or not.  I think there are parts of it missing.  It is his patent on an Inductive device or Electrical Transformer.  He uses iron wire and/or thin iron plates to shield the secondary from the magnetic flux.  Can someone explain this device.  It is a very short read for a Tesla patent.  Which is why I think it has been altered.  He talks about having low current in the primary, So as to not affect the performance of the secondary's current output.  He talks about a time lag between the currents that arrive on the secondary coil and the purpose of the shield and its function of keeping magnetic saturation off of the secondary coil.  If someone could put in their two cents on the main function of this Induction device and if its anything other than a clever form of transformer..  Much appreciated.  EL6
The output of the transformer will have a phase difference of 90 degrees to the supply currents and
so the two together can run a two phase motor.
Also the device can be made to be a "constant current" transformer at all loads as described
on page 1 from line 83 to line 89 of the patent.
http://www.google.com/patents?id=-ntZAAAAEBAJ&pg=PA1&source=gbs_selected_pages&cad=2#v=onepage&q&f=false
Cheers
quat
@elementSix
In relation with your reply 16686
Please give the circuit of your device or where can it be found
Hoppy
Quote from: jbignes5 on April 03, 2013, 08:50:04 PM
In Thea first place my post was not addressed to you. Was it?
As for seeing the working model I encourage you to get off your butt and put it together yourself. Do the research and learn how to do it.. Oh that's right you are not here for that... Are you? I am doing the work as fast as my disability will allow. In fact most of my day is spent in pain. The few hours that I have without pain is because I lay my butt down and do no thing but research to get my mind off the pain. I refuse to take narcotics to manage my pain for very personal reasons.
So instead of sitting here demanding others do the work for you, your time might be better teaching yourself about this system and how it works. I am getting vastly tired of this, very quickly. You sit here doing nothing but criticizing anyone who tries to explain the process, including TK himself. He told you where he got the information. Now I suggest you go out and read and learn. But that's below you isn't it? In the first place even if I did show you my plans and the methods behind it you and others will simply dismiss it as a fake won't you. Just like you and others have done to TK. Even when he tells you where he got the information you sit here demanding others to show you it works. Why not prove it to yourself instead. That way there is no chance of faking at all. like I said all the information is in the links I provided and if you read the links you will find out that the magnetic quenched spark gap is absolutely required for proper impulse circuits. It is the explosive nature of that kind of impulse that generates huge movements of current in other matter, especially a copper plate when compared to ground through a capacitor.
It's all there for you to do. I am doing it slowly, now lets see you do something other then demand the answers.
I won't be posting here again for a while and I bet nothing will be done and a million other non related schematics will be posted. Prove me wrong.
The fact that you referred to my name in post 16683, which I replied to, then yes it was addressed to me.
I'm not demanding others to do the work for me. I have a workshop full of coils, caps, inductors etc, etc, and am always experimenting, so don't give me all that 'get off your butt crap'.
I can't see it will make any difference to the progress of this thread whether or not you take a break. Yes, I have no doubt that there will be many other schematics posted that may or may not be related to the Kapanadze before page 2000 is reached. As to whether I dismiss your Kapanadze replication model as a fake, (if and when I eventually see it) will depend on how well its presented, so don't forget the claim for a self-running model requires good measurements and build detail for replication if it has any chance of being taken seriously. TK has a long way to go on that score.
