0 Members and 399 Guests are viewing this topic.
Hoppy
Quote from: a.king21 on April 04, 2013, 08:46:53 AM
NO!
Have you built Alexkor's self-charging circuit shown in the PDF you posted. If so, have you discovered anything interesting?
jbignes5
Quote from: Zeitmaschine on April 03, 2013, 09:45:23 PM
Energy from which source? The Earth's electric field?
Actually it is easy. The ground and the atmosphere make up an infinitely charged capacitor. But we can only reach the lower ground plate of this capacitor and not the upper atmospheric plate. So we put a 3rd plate between these two plates. What do we get? A smaller but also charged capacitor perhaps?
Imagine two ordinary capacitors connected in series. The two outer plates are charged by a high voltage DC generator. Now what to connect to the middle plate in order to draw energy from the static electric field between the two outer plates? It has to be something that creates an oscillation because capacitors pass AC but block DC signals. Furthermore this oscillation should act like a valve so the energy drawn from this capacitor plate stays in the oscillation circuit and can't flow back into the capacitor.
Is there anything wrong with this simple idea? :D
Ok now look for the special transformer that Tesla talks about in this link. He calls it an oscillation transformer.
http://www.tfcbooks.com/tesla/1919-05-00.htm
It also talks about how to harvest from the one wire (single capacitor plate).
The transformer he mentions starts with this lecture: http://www.tfcbooks.com/tesla/1891-05-20.htm
Figure 113
This is a solenoid primary to a bifilar secondary.
And gets modified to this version: http://www.tfcbooks.com/tesla/1892-02-03.htm. Figure 3 one year later or so.
This version is a bifilar primary to a selectable solenoid or bifilar secondary depending on the connections made to the secondary.
In order to use the energy from this process you must redesign the inductive loads via the pancake bifilar coils. This gets rid of the choking effect that regular solenoid coils show and essentially reduce that to nothing but the resistance of the wire used in the pancake coils.
verpies
Quote from: Hoppy on April 04, 2013, 07:48:46 AM
...to increase its capacity sufficiently to run his lamp array for long enough to convince the punters that he is running on free energy?
...but not long enough to miss their flight out of Tibilisi.
forest
Never forget that Tesla had a large power generators behind his setup ! DO NOT COMPARE charging a HV capacitor from a mA source with that.....the problem is in spark gap loss creating a weak transmitter ....  a tip from uneducated man  ::)
verpies,
please explain us how we can have a HV tank circuit to accumulate energy if spark gap is transmitting it all around and we have a mA power source behind our apparathus.... is there any way ? could magnetic quenching be related or rotary breakers ?[/size]
anandml
 EM radiation causes an electric current that races around the cage and eventually loses its energy to heat due to resistance, Tk's tin can video we can able to see heat dissipation from top layer (ON/OFF toggle switch) of tin can. Does faraday cage to block out radio frequencies or static electricity?
