0 Members and 401 Guests are viewing this topic.
verpies
Quote from: anandml on April 04, 2013, 12:03:30 PM
Does faraday cage to block out radio frequencies or static electricity?
Both.
It also blocks high-frequency magnetic fields, via opposing eddy currents and/or flux shunting.
Hoppy
Quote from: forest on April 04, 2013, 11:45:18 AM
Never forget that Tesla had a large power generators behind his setup ! DO NOT COMPARE charging a HV capacitor from a mA source with that.....
Yes, a point that seems to be overlooked by some writers when comparing Tesla tech to TK self-running tech.
verpies
Verpies,
Please explain us how we can have a HV tank circuit to accumulate energy if spark gap is transmitting it all around and we have a mA power source behind our apparatus.... is there any way ? could magnetic quenching be related or rotary breakers ?
If by "HV tank" you mean a parallel connection of a capacitor and an inductor, then any EM transmitter of suitable frequency in its vicinity will induce sympathetic oscillations in it.  The amplitude of these oscillations will increase until the internal resistive losses of the LC tank come into equilibrium with the power delivered externally. (related to the Q of the LC tank).
If the tank had no resistance (infinite Q) then the amplitude of its oscillations would increase indefinitely, but not faster than the energy delivered by the transmitter.  The LC tank can accumulate AC energy and concentrate power, when abruptly discharged, but it cannot create energy by itself.
Yes, the spark-gap can act as a broadband EM transmitter. The shorter the spark-gap pulses* are, the more broadband the transmitter is.  Broadband transmitter has higher probability of matching the self-resonance frequency of the LC tank than a narrowband transmitter.  However if the self-resonance frequency of the LC tank is known and constant it is more efficient to pump it only with that frequency rather than throwing a broad range of frequencies at it.  Broadband techniques are only better at hitting a "moving target".
[ *Magnetic quenching and rotary interrupters decrease the width of the pulse in the spark gap, effectively increasing the broadbandedness of the spark-gap transmitter. ]
P.S.
If you do things like Wesley does recently, then you can stimulate beta decay in matter with the low-power spark-gap broadband transmitter.
The electrons coming out of such matter decay are roughly million times more energetic than ordinary conduction electrons in a wire and carry a lot of energy.
...but, the energy of these high-speed electrons comes at the expense of matter - not from the "ambient" or "Earth's electric field" - concepts, that are cherished by so many people here.
Grumage
ASYMMETRIC TRANSFORMER
Hello to all,
Today I backtracked and re investigated my earlier experiments with the Asymmetric transformer. I improved the design by placing 100 turns 24 SWG (steel wire gague) on a 10 mm Ferrite rod.
Secondary also 100 turns 24 SWG on a Ferrite ring. By placing rod through ring we have a 90 Deg mechanical phase shift.
Now this is where it get's a bit more interesting. Pulsing the rod with 12v Square wave or rather parts of a square wave ( I was using a PWM with a variable duty) I could easily raise  200VDC through a bridge and cap assembly (Resonant). But this is just voltage it has no current. But what I can say is that the input voltage and current pulses are unaffected by any changes that are applied to the secondary side.
The Poser, Does anyone know of a way of transfering Current Asymmetrically? Perhaps a daft question, if we knew that we would not be at page 1115 :)
Cheers Grum.
verpies
Quote from: Grumage on April 04, 2013, 01:28:33 PM
But do we have a 90ยบ electrical phase shift ?
