0 Members and 358 Guests are viewing this topic.
verpies
But you do have a phase shift.
It is equal to the time depicted by the distance between the two yellow lines.  Note that the two green dots are offset in time (phase shifted).
The red line is a descending ramp and its slope represents the rate of change of the output in response to the input.
P.S.
You input is not a square waveform. It is a rectangular waveform of low DUC.  For longer input pulse widths, the phase shift would be larger.
a.king21
Quote from: Hoppy on April 04, 2013, 10:16:47 AM
Have you built Alexkor's self-charging circuit shown in the PDF you posted. If so, have you discovered anything interesting?
I haven't built alexkor's circuit because I am doing ok with my builds.
In response to Zeitmaschine: the bridge is placed in parallel with the spiked back emf coil to harvest the gating of the Bloch wall.
jbignes5
Please read page 75 on from this book please. It talks about the Tesla transformer that I have pointed out. Actual experimentation has been done on this and it talks about the results. A higher amp output to amp input is claimed as well as a voltage increase.
It gets heavy into the math but try to follow it.
http://www.tfcbooks.com/e-books/transient_phenomena.pdf
stivep
I  have question to Mr a.King
I was proven  by me that Colman used non radioactive compound and I used the same
but  influenced by radio wave that compound is activated by means of radiation. a
Radiation comes from  unstable nuclei.
Radiation could be stop by aluminium foil  for Beta
http://en.wikipedia.org/wiki/Radiation
When his crew was in Tbilisi   did anyone from the people have had any  headache.
Was that possible that  Tariel used  Colman  tube and did not use  aluminium foil to stop Beta radiation?
I have got this when  I was doing Lithuania experiment.
Also When you look at that strange  foil - coil-capacitor (in red color) from  TK aquarium  presentation.
There is shiny middle element inside that foil coil capacitor
Is it possible that this might  be Colman glass tube with  two bushing and foil -coil capacitor  is used as a shield or as energy receiver or as  part of parallel resonance circuit tuning to  a frequency of activation ?
would be possible that in Can of bed demonstration  inside was that compound?
Wesley
verpies
Quote from: stivep on April 05, 2013, 12:41:28 AM
a Radiation comes from unstable nuclei.
Not necessarily. You just proved that in certain environments (e.g. inside RF fields) even normally stable nuclei can decay.
There is another way to look at it: The EM environment affects the stability of the nuclei.
There is more evidence of this influence here.
P.S.
The Miles Mathis paper,  I recently quoted, explains a mechanism of the neutron decay as a collision with external electrons/positrons, suggesting that beta decay always has a cause that is external to the nucleus.
