0 Members and 454 Guests are viewing this topic.
a.king21
Stivep: Wesley, no headaches whatsoever, no ill effects at all from my Tbilisi team.
The team was exposed to 4 1/2 hours during the demonstration.
Remember, you and TK were not in good health during your stay.
I have also been informed that during TK's stay in Turkey they carried out extremely extensive and extremely expensive tests for all manner of possible danger to humans. ie x-ray tests, radiation tests, poison tests etc.
Everything came back all clear.
x_name41
hello stivep and congratulations for your successful experiment, but would you explain is there a some connection between your conception and that of the Andrea Rossi and his reactor of cold nuclear fusion?, thanks in advance!
verpies
Quote from: x_name41 on April 05, 2013, 11:31:11 AM
I don't think they have much in common.
In Rossi's experiment the atomic nuclei merge together and in Wesley's experiment, they fall apart.
sparks
Quote from: verpies on April 05, 2013, 04:13:58 AM
Not necessarily. You just proved that in certain environments (e.g. inside RF fields) even normally stable nuclei can decay.
There is another way to look at it: The EM environment affects the stability of the nuclei.
There is more evidence of this influence here.
P.S.
The Miles Mathis paper,  I recently quoted, explains a mechanism of the neutron decay as a collision with external electrons/positrons, suggesting that beta decay always has a cause that is external to the nucleus.
I believe the EM enviroment affects the stability of the entire atom.  When the wavelength of a photon is short enough it can cause ionization of the atom or it can cause radioactive decay of the neucleus.   The photon 1/4wavelength has to be in angstroms.  A longer wavelength and the intensity of the wave has to be increased to elicit the same effects.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
