0 Members and 276 Guests are viewing this topic.
verpies
Quote from: stivep on April 08, 2013, 07:09:49 PM
I  was looking for English version ready to view of it.  If someone has it
I have never seen the Michael Meyer patent translated into English.
All I know about this device is that the Iron rod must be saturated in order for the device to work.
Saturation decreases permeability and low permeability minimizes the skin-effect.  If this is not done, the RF activation/stimulation cannot get inside the rod because the skin-effect prevents it.
The skin depth (d) of the RF penetration into the rod [in mm] depends on the frequency (f) in [Hz], electric resistance (R) expressed in [Ωm] and relative magnetic permeability (µr) of the material that the rod is made out of, like this: d = 503120 * ( R/(f*µr) )0.5
From the above skin-depth equation, it is evident that decreasing magnetic permeability and increasing the electrical resistance of the rod helps RF penetration.
- The permeability can be decreased by saturating the rod.
- The resistance can be increased by forming the rod out of phosphate passivated and compressed fine-iron-powder.
frankidel
I think that you can take that PDF http://library.open-energy.ws/files/-%20Science/Michel%20Meyer/meyer-experiments.pdf.  In the article it is said that with copper we find an harmonic at the frequence of 172753.867 Hz.  If i can translate it would it be helpful Wesley ??
killswitch
Quote from: stivep on April 08, 2013, 02:54:15 PM
In March 30 of 2013 Me and my  friend scientist we activated compound and concluded that Andrea Rossi  might be using Colman  receptivity as  his secret additive.
Do I read it right, that successful attempt to activate some compound is supposed to give a reason to speculate around Colman patent, while you guys were still not even close to extract any useful energy out of the tube?
I can sense your excitement and intention to drag scientist's to sort out all the missing parts like the exact compounds to be used, excitation frequencies etc. but while it is so popular here to blame men in black and government trolls in all the evil then I would think it is easiest to have control over patent offices and make sure nothing 'revolutionary' can be ever extracted out of any published patents. Like it is been said there is always some important detail missing or replaced with misleading ones not mention the possibility to reject or make disappear the whole thing.
Would expect some more proof to be presented before claiming a breakthrough and making big words. So far there is only some silly finger showing in videos and really no additional detail to what is already known from the patent
stivep
Quote from: frankidel on April 08, 2013, 08:29:27 PM
frankidel my friend
Yes it will help a lot
Please  if you can do it it helps  us all
Verpies you are incredible my friend thank you very much for helping all of us.
I'm  good in radio, antennas propagation,electronics, and  material engineering.
I'm not the top gun  in chemistry, however I'm not bad as well.
my friend- the (nick)-
Mysterious Man from Far Away
is  top,top gun for sure. But he is not always accessible.
Wesley
dllabarre
I found this from a post from wattsup
Start translation:
To shake atoms so they render the energy they contain, you must send via a high !important frequency oscillator (in the order of 173 kHz) a wave that is in resonance with the vibration of the copper electrodes. This is via an  !important]oscillating  magnetic field thanks to the   !important]coil winding  that is connected to the oscillator and that covers the copper. One part of the feed current is used to polarize the metal that restitutes (gives back) up to 30 times the energy consumed by the oscillator.
End translation
So in general, the oscillator is pulsing current onto the copper rod and there is another wire from the positive of the battery that goes through a diode and a resistor so only a small portion of the battery power is used to ensure the copper rod s polarized in a fixed manner to initiate a steady positive/negative output off the copper rod. If copper was magnetic, you could have used a magnet to do the same polarization, but since it is not, a small current on one side will do the same thing.
