0 Members and 326 Guests are viewing this topic.
stivep
Quote from: Grumage on April 09, 2013, 12:54:21 PM
Dear Verpies,
PS. I shall be the fall guy for everyone!! How will this energy manifest itself? As bursts of EM? I have a Geiger Muller counter but test's that I carried out late last year using HV/HF just fooled the detector into thinking there were Beta particles being emitted!
The easiest way for me( legal statement)  is to
1 switch on power from transmitter
2 switch it off
3 if than  Geiger Counter  shows on the display that it works!!!
The longer the better.
Wesley
PS: I consider Verpies to be the most helpful body in this area.
verpies
I am but a humble electrical engineer not a Nuclear physicist  :) Could you explain in layman's terms?
It doesn't get much simpler than that.
A beta decay occurs when one of the unpaired neutrons in the nucleus of the atom transforms into a proton + electron + antineutrino.
(or into a proton + positron + neutrino).
The emitted electron (or positron) moves very quickly (close to speed of light) and has million times more kinetic energy than ordinary conduction electrons in a wire. This kinetic energy comes from the nuclear binding energy of this unpaired neutron.  The emitted electron also carries a negative charge like an ordinary slow electron (the positron carries a positive charge).
Mr Brown did not consider that an individual binding energy of this one unpaired neutron, does not have to be the same as an average energy of all the nucleons in an atom.
For coherent beta emission it is a series of very strong and short magnetic pulses @ low PRR, that can be tapped by a simple pick-up coil in the vicinity of the Gain Medium to produce strong pulses of electric current (PDC).
Also a lot of charge will be produced that will form high voltage DC electrostatic potentials.
For an incoherent beta emission only a lot of charge will be produced that will form high voltage DC electrostatic potentials.   See here.
Geiger counters and photo-films will also be activated.
That is an excellent point!
Strong RF can interfere with electronic Geiger counters and give false positive readings.  I warned Wesley about it.
That's why a photo-film is a more reliable radiation indicator.
If the Geiger-Muller tube is shielded with aluminum and the electronic radiation meter still produces positive readings then they can be caused by gamma radiation of RF.
However, if the Geiger-Muller tube is shielded with thick lead and the electronic radiation meter still produces positive readings then they can be caused only by RF.
Temporal correlations between the absence of RF and positive readings also can be used to exclude RF interference with the radiation meter's electronics.  Wesley showed a positive reading after the RF was turned off, thus RF interference was eliminated as the cause.
I think he called it an "after shock", although I would have liked an "afterglow" better.
Grumage
Quote from: guruji on April 03, 2013, 04:17:32 PM
Seems that the green box is an aluminium wrapped foil as a cap.
I found this pic in a russian site:
Hello all,
Remember this? One of my former colleague's is Lithuanian and kindly did an interpretation, see attached.
He said that the writing above the coil L1 means something about turning the wire around?? Sorry perhaps not much help but could mean the spacing between. 25 turns on 250 mm?
Cheers Grum.
Grumage
Quote from: verpies on April 09, 2013, 01:49:06 PM
Hello Verpies,
Well isn't that statement the clincher? I am sure I saw a video where there was lots of flowing charges leaving a device?
Cheers Grum.
stivep
Quote from: Grumage on April 09, 2013, 01:56:47 PM
Hello all,
Cheers Grum.
F ( frequency) 100kHz
LC 160mH
C1 0.1microF
L1  25 micro H
at 250mm  length -  former of coil is occupied to reach desired inductance.( but not stated as if it is  entire length of former)
25 is number of winds
Can someone post original picture of  capacitive coil( coil capacitor) of TK aquarium?
usually that picture was in red color.
can you scan it in edditing program - different color  filters to expose more?
Can you  look at shiny object inside right in the center of it.
Could that be Colman glass tube with  end cup exposed?
that would lead us to where TK  hided  his reactor.( if any)
Could you fallow wiring from that to see more?
Wesley
