0 Members and 355 Guests are viewing this topic.
bolt
Quote from: stivep on April 09, 2013, 07:14:14 PM
1.1kWh
Wesley
No that is wrong that is a measure of energy plus time.   The device can provide 1100 watts according to the patent.  = 1.1 kW   Its capable of producing
674,520 kWh's!!   before it needs replacing.   At 15 cents a unit it can produce over $100,000 worth of electricity:)    Some people will be pissed if this came to the market.
stivep
Quote from: bolt on April 09, 2013, 11:29:40 PM
1.1kw/h is the energy of 1.1kw during  1 hour
that is what I understand from patent.
and is that because  after one hour there is a need for another 15s of charging time but from very low power.
That stays about energy extraction from  nuclear bonds of unstable nuclei ...... that also is prove of transmutation
Wesley
But yes someone will be very much pissed of
f...  them too...however if I "love them so much" I would like prefer 30 grams instead of 30 milligrams
And in the future 3kg of Colman  mixture :)
bolt
I  be happy to see the mg version first without going to grams!   Don't have a problem finding pure cadmium, copper powder or zinc powder. Phosphorus in elemental form highly reactive and dangerous. Can get it in stable compound forms and oxides.  Lithium, Cadmium and Calcium  all undergo transmutations easy.  They are nuclear unstable and easy suck neutrons which is why they are used in batteries.   But I need more information and alternatives for the chemical filler mixture.
10mm 20mm and 30mm Quartz glass tubes can be found in the fish tank section under UV lamps:)   10mm Brass studding reduced to fit tube then mounted in to sprung holders alike halogen flood light tubes with brass nuts. Be aware this tube going to get EXTREMELY radioactive and IR hot . Lead shielding required.
UHF ham radio good source of Nuclear trigger!   Cheap on ebay.
Has anyone thought about "nuking" a nickel metal hydride battery?  We might get an AA battery to provide 20v @ 5 amps for 10 years:)  All batteries undergo some minor nuclear transformation and dissociation but the normal chemical action is terribly inefficient.    If you doubt this then only have to consider two metals twisted together as a thermocouple produce a voltage when exposed to heat. This is a minor nuclear dissociation process that produces free electrons.
  Almost any metal can undergo dissociation just some much easier than others. Including gasses. For gas use UV light which is modulated and polarised should do the trick.
Rossi uses Hydrogen and Nickel (hydride) Reactor.   I bet he uses modulated UV to crack hydrogen and use that electron to dissociate  nickel.
verpies
Quote from: bolt on April 10, 2013, 03:32:14 AM
According to this patent, all isotopes that have exposed neutrons can undergo beta decay.  This patent even provides a list of some good candidates.
In normal environment the beta decay of these isotopes is prevented by a large nuclear parity and angular momentum difference before and after decay, but adding spins to the nucleus, by NMR or just RF, makes this difference much smaller and the nuclear rearrangement becomes much more probable (faster).
BTW: NMR is more efficient than pure RF in adding angular momenta to the nucleus (Watts vs. kW of RF power).
Also, if EF NMR is used then the device becomes sensitive to its position on the table.
And I thought that he uses Nickel to trap Hydrogen inside its crystal lattice, just like Pons and Flashman did with Palladium.
Rossi's output is heat, not an organized stream of beta particles, isn't it?
Hoppy
Quote from: verpies on April 09, 2013, 04:58:47 PM
Nickel-62 has the most tightly bound nucleus of all elements.  It is a poor choice for stimulated beta decay.
The high binding energy of Nickel isotopes in general makes nickel an "end product" of many nuclear reactions.
Otherwise, the idea is viable if :
1) the iron core of the transformer is saturated by high DC in the primary winding (in series with a HF choke).
2) a proper activating RF signal is applied to another primary winding. Preferably a winding that is perpendicular to the first.
3) the core is large enough so that the beta particles do not escape it - that means large enough to contain their Lorentz orbits inside the core.
The BASER's schematic diagram indeed resembles a transformer.
As TK is supposed not to have used any high capacity batteries to power his devices, would just a short burst of saturating DC be sufficient or would this need to be constant?
