Gidfactor
Hello verpies  in the first video just when he stopped the motor for the guy to take measurements I heard a hall sensor screaming to lock the rotor in to step.
Could it be that the whole setup is motor drive driven and the pillow block down there has batteries in there if u look closely into the aluminium box you will find a red led still lit in there.
Cheers...
verpies
Quote from: Gidfactor on April 10, 2013, 08:37:00 PM
Hall sensors are noiseless.  At 6:12 I heard a little LF buzz when the rotor was stopped, wires to the rotor were disconnected and the 9V battery was connected.  The high frequency screeching is typical of a belt drive at low rpm.  It is absent after the belt is removed after 14:51.
Of course there could be belts hidden in the pillow blocks and a motor between the double channels that the base is welded with.  The only argument that I heard against that hypothesis was that belts provide so much friction that the rotor would spin-down faster if they were hidden in the pillow blocks.  It's a weak one.
Also, TK openly admits that there are batteries in the aluminum box. It think he claims the aluminum box is responsible for generating the activating signal to the brass disks.  You'd need somebody who speak Georgian to confirm what he's saying (if it matters).
frankidel
Quote from: stivep on April 08, 2013, 10:25:49 PM
frankidel my friend
Yes it will help a lot
Please  if you can do it it helps  us all
Verpies you are incredible my friend thank you very much for helping all of us.
I'm  good in radio, antennas propagation,electronics, and  material engineering.
I'm not the top gun  in chemistry, however I'm not bad as well.
my friend- the (nick)-
Mysterious Man from Far Away
is  top,top gun for sure. But he is not always accessible.
Wesley
Here you go, i tried my best but i'm not fully bilingual  ;)
jbignes5
Quote from: NoBull on April 09, 2013, 08:11:36 AM
No, your take on the operating principle was quite different.
Then decide whether the gain medium is something across the spark gap (impulse discharge) or the copper itself.
You may be talking about a device that is constructed similarly, but you had never written about energy from induced beta decay in copper, zinc or iron.
You only wrote about energy from vacuum and aether - never about the conversion of matter into energy.
A couple of commonalities in construction does not make it the same exact method of operation.
My take has always been that the spark discharge into the heavy copper coil excites the inner coil period. there is no transmutation of anything. It simply excites the atoms of the copper back and forth and this is the inertia that Tesla talks about. Using it in the right way is another story.
I have never talked about beta decay because there is no such thing. There is no electrons just the electric potential of the atom itself. Wow you guys really don't get that do you? This is an electric field excitation of matter. In order to take advantage of this you have to approach it differently.
You can give this any definition you want and say there it is different then what you have been saying for 700 pages. Look back and you will see around page 600 I stated such and have been trying to teach people about the electric field, not the magnetic. In magnetics you have a balanced system. It must be because it is circular. With the electric field it is longitudinal. Two very different concepts but the stubborn ones don't ever want to capitulate. Instead they make names up and make believe electrons to explain it differently then what is explained so very easily by the electric field.
The commonalities are the exact process I have been talking about all the while. The only differences is the new names beta and electron... Total BS..
If the electron exists then show us all this marvelous particle. Not one bit of evidence is there to show the electron, in fact it changed from electron to the electron cloud. I have always stated the cloud was exactly like our biggest example, the earth. It is an electric field with a surface, with magnetic cross field.
So yeah change the terminology then claim it is different then what I have been trying to impart the whole time. Whatever...
Ask stivep what my real responses were all the time. He knows.. Obviosly you don't with such a low post count... Go back and look and stop trying to lay some BS...
