0 Members and 141 Guests are viewing this topic.
NickZ
  @ NoBull:
  Quote:
What medium? Do you mean the 19th century Aether ?
If "yes" - What are the properties of this medium and experimental evidence for its existence and measurement of its properties?
        End quote.
   That's where you lost me.
   I guess that Tesla must have been wrong, also.
   Or things have changed, in this century.
  Earlier we were discussing the possibility of obtaining free energy from the ambient. Now it's beta decay???
   The yoke device was said to produce 1kw, but only shows lighting a 150 watt bulb, possibly less than normal brightness. Not 1 kw, why?  What were the negative health results?  I've experienced none.  At least that I can mention.  If that device actually produces a health hazard, shouldn't we All be aware of that?  It could not be replicated, because of a special yoke???  Sorry but, it's a all bit odd all the way around.
Now beta decay, ok, what can actually do?
   Nick_Z
NoBull
Quote from: NickZ on April 11, 2013, 07:29:22 PM
I lost your understanding or I lost you as a reader?
I don't know much about Tesla's beliefs but in the 19th century most scientists believed that space was filled with a magical substance called the Luminiferous Aether through which light and lightning propagated.  It is quite probable that he believed it, too.
Then Michelson and Morley came along and did their famous experiment to measure Earth's motion through that Aether and found no indication of it.  Others have calculated that it must possess contradictory properties such as that it must be a fluid in order to fill space, but one that was millions of times more rigid than steel in order to support the high frequencies of light waves. Aether also had to be massless and without viscosity, otherwise it would visibly affect the orbits of planets, additionally it appeared that it had to be completely transparent, non-dispersive, incompressible, and continuous at a very small scale.  Eventually the whole idea of Aether was scrapped as unnecessary.
Read this link for a fascinating history of the Aether concept.
I never accepted that something from nothing is possible thus I never discussed obtaining free energy from the ambient.
If you think that energy from ambient or vacuum or plain nothing is more probable than energy from matter then you should make experiments that show that vacuum of space is something more than just a geometrical reference system. e.g. that it is endowed with certain properties that can be measured and eventually used to our advantage.
Personally, I think it is more probable to obtain energy from air than from vacuum.  After all, air is matter.
Beta decay is one of the proven methods that nuclei (a major constituent of matter) can be converted to energy.  Other methods are chemical (meaning that they only use the bonding energy between atoms).
If you know of a better process to extract energy from matter, please do tell us.
I don't know that much about the Yoke device.  All I know is that its power was never measured rigorously and that it had two modes of operation: ~100W and 1kW depending how the core was excited (HV or sth like that) and that it was notoriously hard to tune.  One detail struck me as unusual - one of the windings on the Yoke transformer was perpendicular to the other windings.  That doesn't happen in regular transformers.
Ask Stevep, his friends were working on it and got sick and scared.
It can produce short DC pulses of current in the kA range or high voltage DC output.  See this link for the DC mode.
In a nutshell, 1kg of brass could yield the same energy as burning 20000 liters of gasoline...in the form of electric energy (without going through the heat/pressure/mechanical) conversion.
stivep
  @ NoBull:
        End quote.
   Nick_Z
Well understanding of event changes with time  when  angle of perception is altered by new experience.
That would explain progress in general.
In Lithuania Experiment  have seen 60, 150, 600 W
1kw id did not see but Aidas and Arunas have seen.
In one video there  was halogen bulb I do not remember if that particular one was 600W at the time of video but I have seen 600W  for sure.
The real energy was milliW after  impedance mismatch delivered to yoke.
The side effects was what we did not know  - at now I could assign to Alpha Beta Gamma and possibly  more.
Similarity between any of possible of your experiments ( if any)is in process of  extracting energy but not with cristaline   composition of ferrite  as I remember when I was child My father  (teacher) told me Do not sit next to tv it is harmful.
We have had Rubin Topaz and some more of TV of Russian origin.
That warning was based on public experience  as real scientific evaluation was forbidden ( communism)
All of that contributed to me being perfectly comfortable with  testing  of Colman device.
I new what to expect and I have had  proper instrumentation to see it at this time.
When I got to  Army  ferrite excitation and transmutation using radio waves I know that something must be in there.
That is why I try it,
But I admit that Colman was not my idea I was told by my friend scientist
nick( mysterious man from far away) that I'm the only one he knows  who can do it with all respect  to absolute truth
I got than no choice but  to not disappoint  him
I give it a try.
He brought with him all chemicals
I was not even testing the  tube but after connecting it to transceiver I found by accident that it  perform as an antenna for 70cm with acceptable  SWR.
And only than  After longer QSO I have noticed that I pin needle  to maximum.
Radiacmeter was  with probe on its cradle and  was kind of high say not to close to  tube.
I got scared that John my friend is going to be  upset that I pin his  meter.
and he did  after seeing video
That how it  begun
I see now perfect base to real  practicality.
So what I'm waiting for?
Scientifically professionally lab made compound with conductive copper and zinc.
There are few places  I have contacted  to  The cost in not important I do not pay for it :)
And plenty  of it.
Wesley
ramset
Wesley
You have Big Kahoona's [that's a compliment in the Bronx ='}
thank you for being so Brave and for sharing your hard work !
You inspire!!!
Tell Nick thank you Too.......
Chet
Thanks Grandma
NickZ
  @ NoBull, Wesley, and All:
   Yes, and Yes. You lost me on both counts.
   You should read up on Tesla and his findings before knocking his theories.
The Aether is more than just an unproven theory...
   Concerning beta decay... Thanks for the information, but, what does that have to do with what Wesley is working on,  that will save the world,  revolution? etz...
  Looks to me that the Edison battery idea has not been replicated, or proven. In the sense of the stated 10kw output, run time, from a 15 to 30 second charge.
Or has It???  And by who?
   I really am interested in this effort, (Wesley's newest rave), especially after spending many, weeks, and months, of working on the "Crystal Cells" projects, only to find them nothing more than weak galvanic cells, at best.
  My concern for the health hazards of the yoke device, is no joke, as I am working on these devices daily, and have not experienced any health related problems.
  The only reason I bring it up the yoke device is because of all the 1000 + pages of posts on this thread, it was the ONLY device that could be replicated, but was not made to produce the stated output, at least by those that made the some attempt at it. Why not?
I would have liked to have actually seen it light up 1000 watts of incandescent bulbs, as was mentioned that it could.  1kw output???  As of yesterday? Wesley, come on...
