0 Members and 141 Guests are viewing this topic.
stivep
Quote from: NickZ on April 11, 2013, 09:03:26 PM
  @ NoBull, Wesley, and All:
   Yes, and Yes. You lost me on both counts.
   You should read up on Tesla and his findings before knocking his theories.
The Aether is more than just an unproven theory...
   Concerning beta decay... Thanks for the information, but, what does that have to do with what Wesley is working on,  that will save the world,  revolution? etz...
  Looks to me that the Edison battery idea has not been replicated, or proven. In the sense of the stated 10kw output, run time, from a 15 to 30 second charge.
Or has It???  And by who?
   I really am interested in this effort, (Wesley's newest rave), especially after spending many, weeks, and months, of working on the "Crystal Cells" projects, only to find them nothing more than weak galvanic cells, at best.
  My concern for the health hazards of the yoke device, is no joke, as I am working on these devices daily, and have not experienced any health related problems.
  The only reason I bring it up the yoke device is because of all the 1000 + pages of posts on this thread, it was the ONLY device that could be replicated, but was not made to produce the stated output, at least by those that made the some attempt at it. Why not?
I would have liked to have actually seen it light up 1000 watts of incandescent bulbs, as was mentioned that it could.  1kw output???  As of yesterday? Wesley, come on...
As I said everything is in the compound,
Edison did not know that  pencil battery of his time is capable of more than weak voltage out.
Hendershot found it  I assume by accident.
Yoke of Rubin TV must of have activating compound and that what  Lithuania experiment was for.
You my friend dealing with different cristaline  and different frequencies of  activation
http://library.open-energy.ws/files/-%20Science/Michel%20Meyer/meyer-experiments.pdf
this one uses 21MHz
http://www.sciencedirect.com/science/article/pii/0022369771900369[/font][/size]
this one 555MHz
and
300 to 470 MHz which has been identified with Mn ions (replacing iron)
that is also ferrite.
Colman  uses 300MHz
I used  around 430MHz
Everything  above  goes around and around one principal phenomenon NMR
nuclear spin  and precession
Wesley
verpies
The unusual thing is that Wesley is detecting nuclear decay products from matter that does not decay in the normal environment.  Mainstream science claims that this is impossible, so this is an anomaly.
The nucleus contains million times more energy than the chemical bonds, so it spells a revolution in the quantity of energy extraction from matter.
Beta particles can be converted directly to electric current (they are already speeding charged electrons).
A lot of electricity from matter without moving parts is a revolution, don't you think so?
P.S.
Wesley is artificially stimulating the release of energy from the nuclei by spinning them up with RF or NMR or EF-NMR.
Also, I don't believe that Aether exists, but that makes no difference to Wesley's experimental results.
verpies
Quote from: stivep on April 11, 2013, 08:40:00 PM
So what I'm waiting for?
Scientifically professionally lab made compound with conductive copper and zinc.
I predict that the well-conductive copper/zinc will not work as well as passivated copper/zinc, because of the skin-effect penalty.
Baking powdered copper/zinc in air usually adds insulating oxides to their surface - it does not remove them,  thus I expect your old home baked mixture to work better than the new one from "scientifically professional lab".
Experiment will tell...
NickZ
  Verpies, and Wesley:
  Thank you for your responses.
   One thing that I can mention about my ferrite yoke experiments:
That after a certain amount of run time the yoke core will change frequencies, and the Cfls will light to a much brighter degree. The normal mA draw of about 500mA on 12v, will then make the transistors heat up, although the input is the same. I have not been able to correlate this effect with any other known effect generation, or can explain why this happens. It MAY be due to this ferrite transmutation process. This can happen at about 5 minutes plus running time , or longer, but not in less time. Also does not happen with most Cfl bulbs, only certain ones.
I'm still working on this... and changing the circuit almost daily, in trying this and that...
Just thought that I would add my two cents.
   The fact that you or I don't agree on the Aether source, does not change anything.
It is what it is.
Where do you think all electricity comes from, when magnets are spun around coils.   Copper ions, free electrons... I don't think so...
stivep
Quote from: NickZ on April 11, 2013, 10:22:01 PM
It is what it is.
I found the problem with yoke to be similar to Colman
Not enough power.
when I was  scanning Colman with 200mW generator  from 10 to 500MHz nothing happened
But when I gave to Colman 25 W of RF than I got activation.
I'm not really sure that my 430MHZ is the right  frequency  at all
That might be harmonic response  as well
Maybe  a lot less power is needed at fundamental frequency.
It is just that my transceiver does not  give me 300MHz but only  Ham radio 70cm band.
And that is what was  responding.
so all you need is power it is like PA in HF amplifier  there is minimum  driving force for it to  even start.
Wesley
