0 Members and 141 Guests are viewing this topic.
verpies
Quote from: stivep on April 12, 2013, 12:03:01 AM
But when I gave to Colman 25 W of RF than I got activation.
...and after the impedance mismatch is accounted for, the RF power delivered to the Colman tube is much less than 25W.
so all you need is power it is like PA in HF amplifier
...or an impedance matching transformer.
That might be harmonic response  as well. Maybe  a lot less power is needed at fundamental frequency.
...and the frequency probably is sensitive to Earth's Magnetic Field like a compass, thus the position of the device on the workbench will affect it
(as well as rebar, electric wiring, transformers, steel objects: anvils, lathes, etc...)
verpies
Quote from: NickZ on April 11, 2013, 10:22:01 PM
That after a certain amount of run time the yoke core will change frequencies, and the Cfls will light to a much brighter degree.
That might be good - a sign of something unusual happening.
It MAY be due to this ferrite transmutation process. This can happen at about 5 minutes plus running time , or longer, but not in less time. Also does not happen with most Cfl bulbs, only certain ones.
It might be the CFL bulbs or external magnetic fields or temperature. Transmutation can be confirmed with a Geiger counter or a sensitive photo film sealed in plastic only.
What frequencies are you using, anyway ?
The fact that you or I don't agree on the Aether source, does not change anything.
Yeah, for engineering purposes it does not matter much whether the source of energy is explained as transmutation or aether.
Where do you think all electricity comes from, when magnets are spun around coils.
I think that two dimensions of the 3D scalar motion of matter are partially canceled by the 2D motion of varying magnetic field, leaving one dimensional unbalanced, which constitutes electricity.
My views about about this are very unorthodox, so if you want to know more, PM me so we don't pollute this thread with theoretical stuff.
andrea76
at min 16:03 the motor has a  problem.burned? for high frequency component involved in the magnification process??
http://http://www.youtube.com/watch?v=UKzXTAJJsbM
NickZ
        Verpies:
        The fact that you or I don't agree on the Aether source, does not change anything. It is what it is...
quote:
"Yeah, for engineering purposes it does not matter much whether the source of energy is explained as transmutation or aether."
The statement (above), we certainly CAN agree on.
   I don't care it the power comes from the Easter Bunny, so long as it works.
   I also agree that too much time has been spent on discussing theory instead of hands-on experimenting.
  As mentioned, I've also spent some time working on making some Al/Carbon cells, which were first polarized by high voltage from oscillator circuits. Although this gave some interesting results, this initial polarization power obtained from the circuits and applied to the new cells always faded, in time. Thus the cells lost power.
This polarization principal is similar to the idea that Wesley is working on, and may also come from the same initial source, like the Edison Battery ideas.  TK also may be doing something similar, but by using low voltages, like in the use of the 9 volt battery, or through the capacitor bank, as some others have done. This "kick-start" bump may be doing the same or similar effect, that is, setting up the channels of polarization or flux lines of energy flow.
  I believe that this polarization process to be critical part of having a free energy device. As it is through a similar process that so called "SunLight" is also created on Earth. Which is not coming to us from the Sun, as it still taught in schools, but is manufactured here on Earth, instead.
I won't go into that now, to now clutter up this thread. We don't need to agree on this point, either, just keep it in mind, as it will be confirmed, in the future.
@ Wesley:  Thank you for sharing your work, ideas, and replies...
Much appreciated!
In case that you haven't seen my current multiple oscillator ferrite yoke device, here is a picture of it, running on 12v, 500mA. Cfl is at full brightness.
  NickZ
Grumage
Quote from: verpies on April 10, 2013, 07:40:46 PM
If the electrons are ejected into a circular Lorentz orbit inside the core, then the core will experience a torque, by the same mechanism.  This is exactly what is seen in this video and this video
P.S.
Those brass disks in those two videos are the Gain Media in which the stimulated beta decay takes place and becomes confined.  Either the circular nuclear recoil causes the torque or Marinov bearing motor ...or hidden belts in those pillow block bearings  ;)
In the former case, with such large diameter disk cores, the stimulating frequency can be pretty low (and the evil skin-effect, too).
Also, Wesley experiments with the Yoke device and the Colman device add credibility to the stimulated decay as the modus operandi for those devices.
Dear Verpies,
Many thanks for your comments regarding NMR. I watched both Video's. I have some comments to make.
The first one on your list, in the large warehouse? I looked closely at what you term "Pillow" we in the UK call them "Plummer blocks" Which are a cast iron frame holding a standard Ball race/ bearing.
Now unless the shaft that carries the Disc's has been turned down then there would be no room at all to fit a pulley. But why "plate over" the inside of the channel section???
But my major comment is that when the load was switched off, nothing happend at all to the speed of the Rotor and Alternator assembly. After all a load is a load, surely the speed should have risen audibly? Try it with a Petrol/Diesel set!!!
@ andrea76,
My goodness aren't these videos boring??? However IMO the noise you detected on the Vid sounded rather like the Guy knocked out a phase to the motor while he was using the Clamp meter. Once a 3 phase motor has got up to speed it will run on 2 all be it not very well!!
@ Hoppy,
Love your sense of humour, please don't loose it!! Could you provide me a link to that Vid 2004?? Where you heard that sound of a transformer under duress?
I have had a very checkered career and might be able to idetify something from it.
Cheers to all Grum.
