0 Members and 397 Guests are viewing this topic.
Grumage
Hello to all,
In trying to move forward with the NMR theme and with thanks to Wesley for posting Meyers French notes on the subject.   http://library.open-energy.ws/files/-%20Science/Michel%20Meyer/meyer-experiments.pdf
I spent the latter part of yesterday evening trying out the circuit posted below. I feel this would be a good starting point for any of us as the circuit poses little mystery. After all the supply voltage is just 9 volts giving at best 4.5 VPP output.
I used my Signal generator to drive a single power  transistor directly into a coil wraped around a 25mm dia copper billet. Using my Geiger Muller counter in the viscinity to detect the Beta particles that should be emitted........... Absolutely nothing!!! Just the odd click of normal background radiation.
Now I must confess it was only this morning that I noticed the transformer on the output.    Step up??
Another question. Does anyone think that the coil should be resonant at the opperating frequency? This I did not do.
Well there is plenty there for those that posess a Radiation meter. " Beta" get on with it..........
Cheers Grum.
BTW. The transistor 2N706 is only 20mA at 20 V!!!! Not much power there!!!
ramset
VRAND
First off, congratulations Wesley for replicating and !important]sharing your very exciting experiments on this old, almost lost, technology, keep up the good work!   No load was applied at this time.  The major anomalous event of reading radioactivity, where none should be found, was what was discussed in Wesley's 4 video's.  Looking forward to updates from Wesley's experimental results as they progress in this energy breakthrough  !important research area.
Grummage
I suppose what should be jumping off the page at you boys  if the results thus far are accurate.
Whether we see OU or not We have been exposing ourselves to all manner of such events [during our experiments]for quite some time.
It would behoove the community to learn more about these things [as a safety precaution].
Thank you Wesley
Chet
[/size]
Thanks Grandma
Grumage
Quote from: ramset on April 13, 2013, 07:08:29 AM
VRAND
Grummage
Thank you Wesley
Chet
[/size]
Dear Chet,
I could'nt agree more with your comments. So far I have suffered RF burns to hands, severe upper body muscle pains and this was from just playing with HF coreless SMALL Tesla type coils!!
One reason for having my "Trusty" Geiger Muller swithed on at all times!!! It runs on a couple of D type cells that seem to go on and on.........OU no. :)
Cheers Grum.
ramset
GRUM
Yes you are very wise to have the best possible  safety protocol to insure your safety as well as your loved ones.
Who knows what effects these "experiments" can have on us?
As Wesley already pointed out The old TV's which we have been irradiated with for half a century or more have been doing "Who Knows What"?
Thx
Chet
Thanks Grandma
verpies
Quote from: Grumage on April 13, 2013, 06:28:41 AM
Remember that NMR stimulation requires a static magnetic field and an RF oscillations that are perpendicular to it.
That's right, thus  this circuit is a low power RF oscillator at best.
I used my Signal generator to drive a single power  transistor directly into a coil wrapped around a 25mm dia copper billet. Using my Geiger Muller counter in the vicinity to detect the Beta particles that should be emitted........... Absolutely nothing!!! Just the odd click of normal background radiation.
That's why mainstream physics states that beta stimulation is impossible.
However Wesley and the Reiss patent and solar correlation experiments all state that it is possible with higher RF power.
I think that it is possible at low power RF only in presence of a perpendicular static magnetic field.
Rather an impedance matching transformer to the next amplification stage or to an antenna.
Another question. Does anyone think that the coil should be resonant at the operating frequency? This I did not do.
I don't think it must be but it does not hurt either.  When the capacitance and inductance of the antenna create hiQ resonance at some frequency then the antenna becomes very narrowband and will work only at that frequency.  Effectively an such antenna will prevent efficient frequency sweeping.
It is important to measure the impedance of the antenna at the frequency you are generating with your oscillator.  This will determine how much RF energy from your oscillator/amplifier will get radiated into your sample.  This transfer of power achieves maximum ratio when the impedance of the antenna equals the impedance of your final amplifier's output stage.
NMR frequency of course depends on the gyromagnetic ratio of the elements in the core and the perpendicular static magnetic field...even if it is only Earth's magnetic field.
IMO the size of the core matters too, because it must be capable of containing the orbits of released beta particles.
Without some basic math it will be very hard for you to orchestrate the correct EM environment for the core (frequency, magnetic flux density and core size)
