0 Members and 275 Guests are viewing this topic.
a.king21
I had a lot of discussion with TK and he assured me that his device can power electric cars.
The earth can be replaced with the negative terminal of a car battery.
(Or presumably the car chassis).
I understand the purpose of the earth is to fix a zero  voltage, otherwise the device can drift out of phase.
We disconnected the wire for a few minutes and the device carried on working.
Zeitmaschine: Re the conversation about mountains. Do you have a link?
Grumage
Hello to all,
I am avidly persuing this line.
Using a small sample of Copper within 2 solenoids at 90 deg to each other, larger solenoid providing MF sinusoidal field, smaller solenoid carries the sample and is fed via variable DC current.
With just 8 watts the G/M counter shows little murmers of heightend activity around the "Magic number". I need more power!!!
Can any of you Electronic people come up with a simple Voltage amplifier circuit? I have at my immediate disposal a complementory pair of TIP 3055's The MF solenoid has a DC resistance of 4.2 ohm's.
We also need a frequency range of 100Khz to 1 Mhz. As that is the limit of my signal generator.
The NMR frequency is in harmony with the magnetic field strength. That is, the greater the field strength the higher the frequency required to create the resonance condition.
Once I have a little more power I might try a varying LF AC applied to the sample carrier solenoid.
Cheers Grum.
verpies
Quote from: Grumage on April 15, 2013, 10:41:47 AM
There is a small gotcha here.
The magnetic flux density inside a solenoid is not constant  :(    See Helmholtz coils.
Why would you care about that?  Well, I bet you would like the NM Resonance to take place in the whole volume of your copper core, wouldn't you?  After all, the more atoms are resonating, the better.
...but if the magnetic field varies throughout the volume of your core then different parts of the core will resonate at different frequencies.  This means that if you apply only a single frequency, then only a thin layer of copper will resonate, e.g. 1/5000 of the volume  :(
To involve more than this small fraction of your core's volume, you can do the following:
- Apply many frequencies at once,
- Sweep the frequency quickly (FM)
- Ensure that the static magnetic field in the core is homogeneous (constant)
...The MF solenoid has a DC resistance of 4.2 ohm's.
But what is its inductance?
If we know the inductance and neglect the interwinding capacitance, then we will be able to calculate its effective AC resistance @ 100kHz and @ 1MHz (a.k.a. AC impedance).
The interwinding capacitance might not be neglectable if you used many close-spaced windings.
That's good but RF can also create EM interference with the G/M counter, so beware of that.
Wesley observed an "afterglow" of radiation even after the RF was turned-off so we can be reasonably sure that he was really measuring radiation, not EMI.
Are you sure you need a voltage amplifier and not current amplifier?  Coils are predominantly current devices.
Anyway, take a look at this Transistor Amplifier.  I suggest class A or AB.
The output impedance of this amplifier should be able to handle the 100kHz impedance of your high frequency coil.
This relationship is a welcome indication of magnetic resonance with the RF.
DC + LF AC is appropriate for the polarizing winding. The DC component can be substituted with a permanent magnet (non-conductive magnet preferably so the Lenz Effect does not kill the RF field).
NickZ
    Guys:
   After viewing the TK's 2004 video, where he is showing his device, made from what looks like ordinary everyday type of electrical junk, it makes me doubt that he is using anything involving magnetic resonance (beta decay), or some special chemicals, to make it work.
  TK does not look like a scammer to me, this is my heart felt opinion, even though he is not telling all, the whole truth. He has been freely showing his device to the world for years now, many times, many different projects, and explaining what he can. Explaining what his device can be used for, that it can work anywhere, and even to power electric vehicles, etz...    Like the pierce arrow?
  The Island video, was away from any grid related sources. And now we also hear that even the ground connection is not always necessary, for that kind of device to continue to function. WOW!!!  NO 30 second bump charge, every hour, no special radioactive substances, or RF required, at all.
  The French guy (in the Alps) is showing his version of a TK type of replication, again no mention of beta decay or anything similar. Looking very ordinary, using what looks like regular easy to obtain parts.  So simple you would laugh???
  I mention these things because it looks like the current direction is not going to be able to be followed by guys like me, working on their kitchen tables.  Somehow all this talk of radiation, worries me... using only aluminum foil as protection.
Common guys... what if...  this thing blows up,  in my house???
I'd have to see this project done and safely working 24/7, to really have a go at it.
I hope that Wesley can lead the way here, without having to go through another 1000 + pages of discussion, concerning some things that most of us know little about.
As there are safer ways to obtain free energy, like solar, hydro, and wind powered 100% working devices.
  I STILL don't understand, how Wesley was scared to follow through on his successfully working yoke device (best thing yet), with 1 kw output, using only 10 watts input. Then, drops that device and goes after this beta decay project.  His yoke experiment probably did not even use the special ferrite yoke (Barium? or whatever), that nobody can find yet, if at all. He still had some very positive results. Maybe they just got sick from the Flue or whatever, as nothing was proven, like radiation poisoning, etz...
   Has anyone else had ANY positive results to share (like Wattsup, Itsu, Hoppy, etz...)
  This does not make sense to me.  Just trying to understand... please don't take me wrong. If I see that beta decay device is really the way to go, I'll be on it, in a flash.
  @ Wesley:  Thanks for all you've done, and continue to do. I do appreciate it.
            Nick_Z
