0 Members and 462 Guests are viewing this topic.
Grumage
Quote from: verpies on April 15, 2013, 04:28:34 PM
Are you sure about your value of A(RMS) = (8V*0.707=5.657V) ?   Take a look at the attachment below...
Also  0.8 / 1099000 = 0.000000728 and that means 728nH  (not 0.07μH)
Anyway, the reactance of a 728nH coil at @175kHz is 0.8Ω  (+ any DC resistance of the coil) and you would be hard pressed for an amplifier that can handle a load around ~1Ω.
Most of the commercial amplifiers are designed for 50Ω loads.
The relevant equation for the impedance of your coil at a given frequency is:
Z = 6.28*L*f + RDC
where, Z: AC impedance of the coil in Ohms, L: inductance in Henrys, f: frequency in Hertz, RDC: The DC resistance of the coil in Ohms
Also, the previous equation amended to account for RDC is:
L = (A2 – P*RDC) / (6.28*P*f)
Dear Verpies,
Many thanks for your responce, and yes that should have been 14 V p/p not 8. I am using an audio amp right on it's top edge of performance. It is rated at 4 to 8 ohm impeedance.
Cheers Grum.
verpies
Quote from: forest on April 15, 2013, 02:25:41 PM
I saw different equation for current flowing through inductor  :o ??? Not much more complex but exponential one. Am I wrong ?
The formula with time in the exponent is for aperiodic rectangular voltage waveform applied to an inductor.  For a sinusoidal periodic waveform, the inductive reactance is X=2πLf
verpies
Quote from: Grumage on April 15, 2013, 04:48:37 PM
Many thanks for your response, and yes that should have been 14 V p/p not 8. I am using an audio amp right on it's top edge of performance. It is rated at 4 to 8 ohm impeedance.
So if your sine waveform has 14V peak-to-peak then its amplitude +AMAX = +7V and its RMS value is ARMS= 7V * 0.707 = 4.949V
Assuming that your RDC=0.2Ω and using the equation L = (ARMS2 – P*RDC) / (6.28*P*f)
the inductance of your coil should be 375nH to transfer 40W to it at 175kHz and your amplifier should be stable with a 0.4Ω load (I don't think your amp can handle that!)
To have an 8Ω impedance @ 175kHz the coil should have the inductance of 7μH.
Unfortunately at 4.949VRMS and 8Ω impedance only 3W will be transfered to the coil :(
To get 40W into an 8Ω load, the RMS value of the sinewave would have to be ARMS = 17.9V, because:
ARMS = SQRT(P*Z)
where P: the average power in Watts, Z: is the AC+DC impedance of the load in Ohms (e.g. 8Ω)
Grumage
Quote from: verpies on April 15, 2013, 05:23:37 PM
Cheers Verpies,
I think I need some "Dilithium crystals"!! That should do the trick :)
MORE POWER
Cheers Grum.
@ Zeitmaschine,
Good to see you back, I think you should have mirrored the second pics, they would look really cool ;D
verpies
Quote from: Grumage on April 15, 2013, 05:43:31 PM
Yeah, Scotty, now you have only ~5VRMS at the output of your amplifier and you should have ~18VRMS in order to push 40W into an 8Ω load.
ARMS = SQRT(P*Z)
where P is the average power in Watts and Z is the DC+AC impedance of the load in Ohms (e.g. 8Ω)
