0 Members and 213 Guests are viewing this topic.
NickZ
   Grum and All:
   Thanks for your concern, well taken.  Yes, after I turn off my device at night the Cfls, and myself stay somewhat lit.  I know it must be some kind of decay... mental I think...
   One thing that comes to mind. The Edison battery with it's chemical compounds and metal powders goes into a Alfa/Betta/Gamma decay, which may be somewhat similar to a regular galvanic reaction. But, How would the materials in the tube (those elements) last for 70 years while putting out 10kw?  Really???  Why aren't the many battery hi-tech manufacturing plants using this technology. They don't know about it?   I don't think so...
  There definately is a polarity present from an ambient source, such as a positive and negative flux. regardless of material substance. Energy is not dependent on matter, matter is dependent of energy for its existence. Field energies, and such...
  What I'm trying to say is that this electrical output (beta decay) may not be due to the decay from the breakdown of the elements, but from the ambient that TK is also mentioning. The polarization process makes this possible, for an hour at a time, then equilibrium set in, and the process stops, until another bump charge is given. Or not?
   Yes, the yokes can also produce this same or similar effect, Barrium, or not. But do they?
  I'll repeat myself at the expense of boring all of you: All electricity comes from the ambient.  An electric generator will never run out of energy, no matter if it produces or manufactures it for a million years. Or a solar cell.  Even a galvanic reaction, is a by- product of the produced output, not the cause of it.  We are in the middle of a field of energy, That is what Tesla, Kapanadze, Moray, and many other great men have been trying to tell us, for years. It is this field that needs tapping, not the breaking down of matter.
No wonder that Tariel gets so upset.
verpies
Quote from: Grumage on April 16, 2013, 05:32:06 PM
Present coil is 14 micro H   20 turns   on 2" dia cardboard former using    4mm squared   7 strand  PVC insulated copper wire.
With or without the copper core ?
Anyway, at 175kHz this coil will have an impedance of 15.4Ω.
I have not measured the DC resistance but I could be fairly certain it's under an ohm.
I think so, too.
I do not quite understand why you ask PDC? The output is derived from DC yes, but you have 2 mosfets in a sort of push pull. Creating what I would term AC.
Just by looking at the Y-offset knobs on your scope.  Royer oscillators often have unsymmetrical outputs because the center-tap is not in the middle of the primary and the transistor gains are unmatched.
You know your scope better, so if you're sure the output is pure AC then disregard my words about the DC offset of your waveform.
PS. Do you have a special keyboard for your electrical notation?
I use the ALT-NNNN numeric keyboard shortcuts.  If you don't know them, then you can use copy→paste with the attached text file.
NETIKS
NickZ
You need to ask Your self this question!
Where's the energy coming from!
