0 Members and 72 Guests are viewing this topic.
xenomorphlabs
Quote from: forest on June 04, 2010, 09:02:40 AM
eeee it's just a transformer :(
Show us the transformer that operates exactly like that ;)
Naudin uses 2 earth grounds, where Kapanadze uses only one.
And that seems to be key to Naudin´s set-up.
The yellow thick wire is actually on one end connected to the left earth ground then goes through the lamps into the other earth ground.
So this is the Tesla one wire transmission.
It seems he has also no ferromagnetic core. However there must be a reason why he covered the left opening of the tube with something, so you can´t look inside. So maybe there is rods inside or something.
The HV impulses go into the blue cable that seems to be part of the primary, but since Naudin doesn´t show the backside of the coil, it´s impossible to tell what is going inside the box.
gyulasun
Tesla's work is surely involved somehow because Naudin references Tesla's Colorado Springs Notes at the bottom of his page:
http://jnaudin.free.fr/kapagen/
A good quality PDF file and downloadable  ;)
Goat
Quote from: xenomorphlabs on June 04, 2010, 10:02:56 AM
" since Naudin doesn´t show the backside of the coil, it´s impossible to tell what is going inside the box."
@ xenomorphlabs
For what it's worth....
At 2:20 in the Kapagen v3 Youtube video you can see the MOT connections (more or less) as the input being fed by the grey wire(s) from the ATV3 power supply.  From there one blue wire goes to the spark gap and the other blue wire going to the coil.
I'm not sure how close his replication is compared to the Kapanadze circuit but I look forward to seeing more from him.
Regards,
Paul
the_big_m_in_ok
Quote from: cgx on June 03, 2010, 02:47:35 PM
You can find the beginnings of Naudin's Kapagen page at http://jnaudin.free.fr/kapagen/
A few more pictures of the setup there, sadly no schematics or description yet
I don't think even Kapanadze drew wiring diagrams for his invention in his descriptive videos, right?  Naudin will eventually provide drawings of his test prototypes, however.  He's been honest about that.
--Lee
starcruiser
The design is showing counter wound coils again, the blue coil looks to be RH wound and the 5 turn one is LH wound. The MOT is feeding both ends of the blue coil, one of the MOT leads goes thru the center of the PVC tube to the right side ground/center wire lead. The other MOT lead is connected via the SG and connects to the Left side of the blue coil. Seems to be an electron pump using a smaller coil to provide an imbalance in the bloc wall, thus a diode or gate effect perhaps?
Regards,
Carl
