0 Members and 382 Guests are viewing this topic.
guruji
I don't know if you guys saw this schematic from russian forum
Hoppy
Quote from: Zeitmaschine on April 17, 2013, 07:00:38 AM
Maybe this means nothing but since I love strange coincidences:
Overloaded transformer and shorted turn created by copper pipe leading to high current & NMR?. How to amplify / maintain (after 'kick-start'), control & process?
anandml
Thermoelectric materials(two dissimilar metals) can be assembled into mechanical structures which can transform heat to electrical energy. It will generate less electric power for the same heat flow and there is no chance to produce very much electrical power. Everyone knows about the thermoelectric generator its efficiency is very much low...
verpies
Quote from: NickZ on April 16, 2013, 10:27:24 PM
"All that matters is that speeding electrons can be made to appear radiating out of matter when stimulated appropriately".
That may be all that matters to you, but, what matters to some,  or even most of us is IF this will actually lead to an electrical output. Not just spewing radiation of various unknown and possibly dangerous types out into near by space. And so far there is no indication of that.
Conversion from high intensity alpha, beta or gamma to electric current is just another step in the process, and it is a proven process. It's the easy part and it's a sure thing and has been so for the last 50 years.
CRT TV sets and monitors give out x-rays, which are next to gamma rays. Not a million times less.
If you account for the miniscule intensity X-Rays out of CRTs then they can overlap with gamma or have 100 000 times smaller frequency.  See the attachment.  This frequency defines the energy of only one photon.  The number of photons (intensity) is completely unaccounted for in this comparison.
Betavoltaics - hydrogen isotopes mostly. Not the same thing.
Just because tritium is used most frequently, does not mean that other sources of beta particles do not work, too.
Betavoltaics is just an example that beta radiation can be and is readily converted to electric current.
Also, there are many other methods of conversion.
Ultimately there is no doubt that if intense radiation can be produced artificially, then it certainly can be converted to electric current one way or the other.
Grumage
Quote from: verpies on April 16, 2013, 07:04:41 PM
With or without the copper core ?
Anyway, at 175kHz this coil will have an impedance of 15.4Ω.
Just by looking at the Y-offset knobs on your scope.  Royer oscillators often have unsymmetrical outputs because the center-tap is not in the middle of the primary and the transistor gains are unmatched.
You know your scope better, so if you're sure the output is pure AC then disregard my words about the DC offset of your waveform.
Dear Verpies,
Sorry it's me again!! Having read your  earlier message, am I right in saying that the higher the frequency the harder it is to penetrate the skin? Also you missed my question whether the DC input current would be a reasonable marker for output power?
Moving on please see attached. It is a 1/4 BSP air muffler made of sintered Phosphor Bronze. Now we have 3 elements....... Copper, Tin and Phosphorus. I wonder what the frequency would be for that little mix? But I thought as they are really small particles of material pressed together maybe we could see a result?
On a lighter note for you and all..........  If the answer is 400 mA........ What is the question? ........... Why isn't this Bloody thing working?  ;D
Cheers Grum.
BTW. My Royer oscillator does not have a center tapped coil. Just single coil.
