0 Members and 174 Guests are viewing this topic.
baroutologos
I love to see theories that do not have a single clue of practicality.
Two grounds have a mild electric effect due to telluric currents as many know. N is the possitive south is the negative of them (during daytime). (see wikipedia) By inserting as rods suitable materials eg copper for south and iron for north assists voltage difference.
By the way for such small distances (10m about) we are talking for milivolts. At best positioning of them it is said it can be acheived some single digit volts of current (1-2v).This is hardly a way to extract useful energy.
regarding the counter wound coils, there is absolutely not a clue that they produce any peculiar effect. (Please correct me if i am wrong.)
So, we can not have a clue how this works based on our common knowledge (IF it works at all)
ps: I have read Colorado springs notes. All of it. I do not know how this can be potentially correlated.
I guess Naudin has to illuminate us :)
Pirate88179
Quote from: baroutologos on June 05, 2010, 02:49:32 AM
You are correct about the Telluric currents but I wanted to inform you of some other details.  I get a little over 2 volts from my electrode set up and they are only about 12-15 feet apart, and properly aligned...but, I can light 48" long floro tubes and over 400 leds from this power source using a super cap and a joule thief circuit so I consider it to be useful.  I have run my exterior Christmas lights the past 2 years using this method.
The electrodes need to be far enough apart so they do not react with one another directly. (This is the only way I can explain this)  The further the better from what I have read though.
I noticed this right away when first seeing Kapanadze's videos which is why I began this topic.  I recognized some possible relationship to our earth battery and EER experiments.  The rest of what he, and now Naudin, are doing is over my head.
wings
Quote from: starcruiser on June 04, 2010, 06:25:06 PM
The design is showing counter wound coils again, the blue coil looks to be RH wound and the 5 turn one is LH wound. The MOT is feeding both ends of the blue coil, one of the MOT leads goes thru the center of the PVC tube to the right side ground/center wire lead. The other MOT lead is connected via the SG and connects to the Left side of the blue coil. Seems to be an electron pump using a smaller coil to provide an imbalance in the bloc wall, thus a diode or gate effect perhaps?
Can you design a preliminary connection diagram?
baroutologos
I know Pirate that you have done that.
I may add you are one of few people that can power a decent emergency light this way. (inexhaustible way)
Energy is all around us. From slightest air motion to faintest sunshine. What i am really concerned is about large scale electricity or power creation with ways more cost-efficient and enviromentaly friendlier that the methods used today. If Kapanadze have managed to achieve that, this is a matter of strategic importance to find out by any means.
Regarding the grounds,
I have started in energetic.com forum a thread about ground based energy systems. In my view, ground can offer these practicalities to electricity:
1) Vast capacitance and electrons reservoir
2) A vast conductor for single wire power tranfer (ala Tesla type) or return cable
3) Energy flowing in it as telluric currents of DC nature (diurnal character) and AC nature located on the ELF, LF and various other higher frequencies. (created by solar wind and ionosfere lightning)
Regarding (3) I have argued that if a resonator (a magnifier transformer) could be built and syncronized to some natural LF range (say 40Khz) then a decent power could be extracted.
Unfortunately after some experimentation, i realized that if there is not a "ground potential" to an elevated plate of several hundred volts that is of AC character (eg  40 Khz) (not DC as the Tesla patent about radiant energy goes) then not useful energy could be extracted.
In my experiments, i have not find out any such scale AC voltage between ground and elevated plate. So this theoretical method is a dead-end
On the other hand, the DC nature between two ground or ground and elevated terminal is of very low power generation. (during storms the later way showns quite larger performance)
Regarding (2) this is suitable for power transfer as readily understood and not creation. This is particularly good for tricks!
Regarding (1) do not have a clue how can be usefull, apart from Tesla coil oscillators.
Groundloop
Hi,
Here is my first simple test to see if a Tesla coil in reverse will
transfer energy to the output coil. And it did. I do not have the
nerve to mess around a microwave oven transformer, so I used
a small high voltage oscillator and a spark gap to drive the blue
coil (77 turns). My 3 turn output coil did light up two small light
bulbs. Now I will try to make a better output coil.
Groundloop.
