0 Members and 400 Guests are viewing this topic.
Hoppy
Quote from: Grumage on April 19, 2013, 06:51:42 AM
Dear Verpies,
I am still "Plugging away" at this aspect of research but I am getting quite frustrated due to the lack of any tangible results.
I must be radiating some energy as my sample materials get quite hot due to induction. I have 140 V p/p with 500mA DC current draw to input of oscillator @ 172 Khz. (Large value cap across output of PS)
This current increases with different materials that are placed within the drive coil. A cast iron tube nearly "took out" my Mosfets!!
Is there a significance to Brass? You have mentioned this material many times. I also wonder about whether I actually have Cu63? I presume that no transmutation would occur if the the sample was already depleted?
Finally one other observation. I placed within the drive coil a small solenoid taken from the guts of an old automotive 12V relay. I had a small length of 3/16" dia Brass rod inside said solenoid. Bringing an earth wire to the end of the Brass rod I was able to draw quite a spark. This died when I think the solenoid coil internally shorted!!
Your observations will be gratefully appreciated, and I hope spur me on. As I am rapidly running out of enthusiasm!!
Cheers Grum.
BTW would you have any suggestions to other materials that could be found around the "Normal?" household. Chemical salts etc. From what I have read, all elements can be Treated in the same way!!
Hi Grum,
As you are shooting for bulls-eye, have you tried a lump of old barium ferrite from an old 1960/70's transistor radio aerial or yoke from a TV?
verpies
That's not surprising. I warned you that the Royer oscillator does not have a clean output.
With it, you traded frequency stability and spectral purity, for power.
Notice that you had a little positive effect with your weak but pure generator.
That's because these materials are very conductive.
That's called inductive heating and the amount of heat produced is a good indicator of absorbed RF energy.
Both the copper and zinc have similar beta decay properties.
Also, Kapanadze used brass disks with success.
Yes, you have the natural isotope ratio.  It is very hard to separate them when copper is manufactured and no effort is made to do it.
Yet, but it would take a very long time to deplete.
I don't know what brass rod did inside an automotive relay solenoid. Maybe it was only a coated iron rod.
If you consider the turn ratio between your driving coil and the automotive relay coil then you'll realize that they form a step-up transformer capable of producing HV and breaking down isolation.
You did not mention anything about the polarizing transverse magnetic field, thus I know nothing about its magnitude nor its homogeneity.
NMR is very sensitive to this static magnetic field and to the transverse RF frequency (even ±10Hz makes a difference).  Watch these videos and notice how much difference even a steel spanner wrench can make in the vicinity of the core.
If I were you, I would make a Maxwell Coil for producing the homogeneous polarizing magnetic DC field.  Your other coil (the 14μH one) seems to be OK.
If you give me the dimensions and the DC current in your Maxwell Coil, then I will tell you what the magnetic flux density is in the middle of this coil and what frequency you should apply to your perpendicular 14μH coil to achieve resonance in copper, brass, etc...
Also, I would not trust the Royer oscillator to produce a clean and frequency stable RF stimulation for resonating the nuclei of matter.
Would you have any suggestions to other materials that could be found around the "Normal?" household. Chemical salts etc. From what I have read, all elements can be Treated in the same way!!
I could but I don't want to elaborate on that. Briefly, elements that have a zero intrinsic magnetic spin will not work. For detecting sth with your Geiger counter you don't need a large core, but for producing powerful pulses and electricity you need a sizable core to achieve critical mass for beta self-stimulation.
As a tidbit, I will write that passivating copper powder can be done with heated ammonia cleaner or pool chlorinator or battery acid.
Grumage
Dear Verpies,
Many thanks for your reply, with as usual, your highly valued advice.
Would a 50Hz polarising field be suitable? If yes, I have at my disposal a "home made" resistance welding transformer. This has an output of very low voltage but very high current.
My thought is a few turns of  heavy copper wire would create a massive magnetic field around the sample. One of the problems that has been occuring is that my polarising coils have been melting and fuseing together!!
Also I noted that « Reply #17095 on: Today at 11:05:09 AM » Has a pretty good looking Mosfet driving center tapped coil circuit that looks to be variable frequency.
Maybe this would better replace my "Rotten" Royer :)
Cheers Grum.
For Hoppy,
Many thanks for the hint, but as you are probably aware there aren't many of those beasts left around these days. But I shall have a look in my back shed as I suffer with the "Magpie Virus".... You never know  :)
Cheers Grum.
Hoppy
Quote from: Grumage on April 19, 2013, 11:21:58 AM
For Hoppy,
Cheers Grum.
Grum,
Not really a hint as I have no idea if it will work or not. I suggested you try it just because its claimed to have special properties, so in for a penny in for a pound as the saying goes.
