0 Members and 401 Guests are viewing this topic.
Hoppy
Quote from: NickZ on April 20, 2013, 01:42:35 PM
  It may well be incomplete, (to be expected), but it does show at least most of the same components used. Such as 12v battery source, going to the 12v to 220v ac inverter, twin transistor switching circuit, yoke coil, etz...
  What in your opinion may be missing?  The girl holding it, the tin can, and the price tag? Ha! Just joking,,,,  I think.
Well, L4 is floating in mid air and the inverter oscillator does not look very clever. This is more a building block schematic than a proper circuit diagram that we would need for replication purposes.
Grumage
Good Evening all,
Well this has turned into a lively debate. Good.....
I watched and listened to the selection that Verpies chose again. And as Sparks commented is exactly what I was pointing out. A shock to a disc will cause it to ring. This ringing was drastically reduced by the use of foam in the house video.
Now let us reconsider my remarks from yesterday re the use of a "keyed" magnet. I could see no evidence of such. However Verpies remark regarding the shaft being split between the discs would therefore allow for a long series drill to create 3 long holes towards the end where the Torroidal coil sits.
I feel I have a soloution to Verpies question 4.     Consider a standard 3 phase induction motor. Stator fixed (Torroid)  Rotor (shaft) rotates. Because the rotor is so close magnetically to the stator the motor will almost immediatley reach slip speed upon applying power.. Now with the TK motor A much higher frequency is being used and the "hidden?" magnets are further away from the torroid so a rather slow and ponderous start will occur. The frequency is fixed so therefore the shaft will pick up speed and gradually meet with the opperating frequency. In fact it is quite noticable at the latter part when the rotor has met with it's frequency.
And finally...... Why are there two layers of "C" section channel iron placed one on top of the other for the base of the device?  7 Ah Gell cells? :)
And finally finally...... If there were a stream of Beta particles being emitted radially from each of the two discs would not the CCD in the digital camera be bombarded with them and upset the images?
Cheers Grum.
PS. There are more than two wires going to the torroid in the house Video. A 3 Phase version versus a 2 Phase? :)
Addendum.
It has just dawned on me what the audible high frequency might be. Single phase to Three phase invertors can be programmed for different drive pulse frequencies. For industrial applications a fairly low frequency is used because it gives a greater torque. When we used to fit them to our Lathes and Mills that were destined for domestic use we used to program them with a much higher frequency because it was less audible.
Grum.
NickZ
  @ Hoppy:
   And what about the previous yoke experiments from the Wesley team, that were mentioned as being Tariel's ideas?
  And the new translation done by Wesley recently,  are ok for this thread. Or what?
  I don't agree.  To me this is a much more replicable, and economical, portable, light weight, and no noise project. Which is supposed to come from Hendershot's ideas, but does it really.
  At least this project is WORKING, NOW.  No, goose chase...
  Tariel did not used twin signal generators, etz...as were needed in the previous  replication the yoke device to make it work, which without them it would not function. Nor were they a NO Battery type of device, either. As Tariel was showing... after the kick start.
  Verpies would probably also agree that Tesla would not use the terms "beta decay" in explaining the mode of operation. Or Tariel, for that matter. But, DID use the term Aether, as being responsible for tapping electrical energy from the ambient. 19th century? No a million year in the future. We are like cave men, burning, and exploding things up, still.
  Some people have already suggested that the sole use of a Geiger counter in close proximity to a strong pulsing circuit could very possibly give false reading. This really does needs more testing to prove, one way or another. Don't you think?
  Anyway, I have no problem going to a new thread for this project. But, will not be the one to start one. Wesley was the one that come up with this new project, and I'm most thankful that he did.
                             NickZ
Grumage
Quote from: NickZ on April 20, 2013, 02:22:22 PM
  @ Hoppy:
                             NickZ
Dear NickZ.
Is this the post you are refering to? Reply #17095
If so, I feel that with this schematic and the very well drawn subsquent drawings that I saw there should be no problem in a replication.
However why use a TV yoke? There are so few turns on primary and secondary that a reasonably sized Torroidal Ferrite could be used without too much stress in the coil winding area.
If I wasn't  so "into" my present work it is something I would definitely look at.
To your final commet regarding the use of Geiger Muller counters. I have noticed NO disturbance at any of the frequencies I have been using. The only time it goes haywire is when HV/HF is used.
Before I perform any tests I "try out" my GM against an old Radium painted clock dial........ It goes ballistic!!!
Cheers Grum.
NickZ
  Hoppy:
  L4 is not connected to anything, as is shown on the red yoke coil, in the video, (i think), as it's very blurry.
We need to see if there is something to this, first. Before saying that it's not working, or missing as presented. That is why I asked for help from those guys that can read their forum and web site posts and comments.
  As we have not been able to make this kind of thing happen using conventional electronic theory, I would suspect that the real secret is in the wiring, and coil relations, resonance produced, etz... as there is nothing else that would do the trick, like hidden wires, batteries, etz... which is easy to say, but not prove. That newest diagram is much easier to read, although it may need some additions, corrections, as does the devices itself.
No free lunch, yet.
