0 Members and 548 Guests are viewing this topic.
Bruce_TPU
Hi Groundloop,
Great early experiment, as proof of concept.  JLN Labs is making tremendous progress, I just can't wait to see the details.  I have found the latest here:
http://jnaudin.free.fr/kapagen/
It is not done, but I have posted a picture of his latest progress below.  It would appear very impressive progress indeed...
Cheers my friend!
Bruce
Quote from: Bruce_TPU on June 05, 2010, 03:37:48 PM
Hi Groundloop,
Cheers my friend!
Bruce
Can I ask how you got that picture?
Bruce_TPU
From my referenced link.  Which I got some time ago from another forum.  But I keep checking back on the link...  ;) ;D
Groundloop
Hi Bruce,
WoW, JLN Labs is doing good work.
A normal microwave oven transformer is rated approx. 1000 Watt.
I hope he will post a circuit drawing soon.
Groundloop.
Bruce_TPU
Quote from: Groundloop on June 05, 2010, 04:25:42 PM
Hi Bruce,
Groundloop.
Hi Groundloop,
Check out JLN Labs latest Youtube!  Only 33 minutes old!
http://www.youtube.com/watch?v=aOvuQweJsV8&playnext_from=TL&videos=_RKf_HUp6a4
Cheers,
Bruce
