0 Members and 350 Guests are viewing this topic.
Hoppy
Quote from: Grumage on April 21, 2013, 08:33:58 AM
Good afternoon Hoppy,
The probable reason for this was that the machine was too damnd heavy......All that lead and all!! ;)
I am still waiting on Verpies reply to my recent post but in the meantime I remembered the famous Tesla spinning Egg experimental 3 phase motor. It is quite probable that the shaft could be rotated in this fashion. It is very clear in the Video that the alternator drive belt is very slack hence it's squealing, this would allow for a slow but sure spin up. Drive frequency constant, shaft rotating up to meet it's electromagnetic  rotational speed.
So IMO we have..... PP3 hits relay..... 12 V battery hits single phase invertor...... Single phase invertor hits 3 phase invertor..... Hits Torroidal "Stator".......Drives shaft......Output from alternator then keeps up charge for 12 V........ Appears to be a self runner.
Sorry but that is the way I see it.
Cheers Grum.
Addendum.
Have a closer look at http://www.youtube.com/watch?v=vZC5CwCTv4I&feature=youtu.be&t=0m01s Early on in the video my 2 younger sons spotted the copper straps over the "Plummer blocks". They asked me what they were for, knowing absolutely nothing about the Marinov motor principle!! BTW neither did I before yesterday!!
Grum.
Afternoon Grum,
In this video there is again the possibility for concealed power coils in the box section below the bearing housing on the pulley side. the foam on the ali rotor is likely concealing the rotor magnets around the circumference. this boxing could also house enough nicad batteries to power the motor and illuminate the small lamp for the duration of the short demo. In TK's larger motor, more effort has been made to make the disc(s) look good after insertion of the magnets.
Although some see these motors as uninteresting as they cannot easily be replicated as the more easily bench constructed non-mechanical devices, trying to establish how these operate is important because if it can be clearly  established that the Bedini monopole, or your toroid shaft driven principle is being used, then TK's motors are IMO definitely not self-running. The implication drawn from this would be that neither are any other of his devices shown in his demos!
The copper bands could be passing current to the bearings which I think is what you are thinking if its working on the Marinov principle?
forest
Hoppy
Bad implication my friend ! If ou is hidden inside a black box and running inefficient motor it's still ou. >:(
Do not try to suggest such opinions as in your last comment please ! It's a purely discreditation tactic ,used mostly to ridicule people and depreciate their work. Well...I would say that your intention is somehow visible through such statements...  :o Am I right ?
Hoppy
Quote from: forest on April 21, 2013, 02:54:43 PM
Hoppy
No Sir.
a.king21
I think we should focus on his patent applications. There is  a common thread in there.
ie live output goes to earth.
2 coils at centre of patent
3 output on secondary side of the device.
4 output looped to input.
5 high frequency on/off switching.
And on his physical builds:
:-ordinary trafo linked to his high frequency bifilar wound trafo.
:-earth leads near a water source.
etc etc etc.
I would welcome a discussion on different types of high frequency trafos, and windings, because his device has to have them.
I do not think his device is fuel based because I know of no way you can set up an infinity loop with such a system as the output could never be greater than the input.
The fact that he admits to an infinity loop is a logical consequence of spiking the vacuum.
I also think that TK has access to different OU builds as he has admited to buying (illegally) a book from the Russian Academy of Sciencies on free energy.
This explains why one of his first builds was a HHO device.
WE SHOULD TRY AND GET A COPY OF THAT BOOK.
Hoppy
In my post 17160 I wrote the following:-
"In this video there is again the possibility for concealed power coils in the box section below the bearing housing on the pulley side. the foam on the ali rotor is likely concealing the rotor magnets around the circumference. this boxing could also house enough nicad batteries to power the motor and illuminate the small lamp for the duration of the short demo. In TK's larger motor, more effort has been made to make the disc(s) look good after insertion of the magnets."
I should have said that any batteries could easily be stored in the base of the aqua as there is probably a space covering the full area of the base with a depth represented by the depth of the metal channel section forming the structural base of the aqua. The box section below the bearing housing would just house the power & trigger coils. The air gap between rotor and coil is quite small compared to the big motor device and this may account for the faster acceleration of the rotor in the aqua video.
Notice at around 04.03 how freely the shaft turns just after the toroid coil is fitted in its housing. The small genny is still belt connected to the motor at this point!
I'm also wondering whether the rotor magnets are possibly electro-magnets given the wire coil on the axle with each end disappearing into a disc??
PS: There is a wire coming out the end of the shaft that the toroid fits over. Could there be a slip ring arrangement in the hole of the toroid to take power to electro-magnets in the rotor with the return path being through the metal axle? If the magnets were electro types then this may allow for starting by pulsing them which would create a kick against the iron core of the power coil, which in turn could induce enough voltage and current in the trigger coil to switch the power coil.
Edit: On further close examination of toroid, I can see no evidence of a slip ring arrangement. However, could the toroid be inducing a current into a coil within the shaft, assuming it is a hollow tube and not steel but say aluminium?
A simplified schematic of likely arrangement: -
