0 Members and 479 Guests are viewing this topic.
Pirate88179
Bruce:
On this video, it appears he has moved his grounds further apart.  Man, that spark gap was really smoking this time.  I wonder if he has to adjust it to stay in resonance as he increases the load?
Bruce_TPU
Quote from: Pirate88179 on June 05, 2010, 05:33:19 PM
Bruce:
I'm not so sure.  I thought so at first and then rewatched it a few times.  In the first part, he zooms as he shows the wire off to the viewers right.  Difficult to tell.
I do know that he moved the bulbs off of the device onto the wood off to the side, for the best results.  The load may have been interfering with the resonance, perhaps, where it had been.  Much stronger output after the load was set off to the side.
Cheers,
Bruce
xenomorphlabs
Quote from: callanan on June 04, 2010, 06:55:53 PM
In Kapanadze's original and long video, one ground is connected to a car radiator buried in the ground and another ground is connected to the back yard house water tap pipe. Are we so sure he didn't use both grounds?
The radiator was used to show that it is not as efficient as the water pipes, going deeper into the earth. No 2nd ground cable can be seen in that video.
In his recent video there is also only 1 ground cable going to a steel girder.
iflewmyown
It looks like Naudin is using a variable frequency motor drive unit for the input to save winding the coils to a particular frequency. Does anyone have any info on this unit? The only marks I can read are {  ATV3  } . Thanks
Garry
baroutologos
It is getting more and more interesting.
Why he posts videos and photos of bulbs lit and does not presents schematics and principle of operation?
