0 Members and 97 Guests are viewing this topic.
yfree
Quote from: verpies on April 23, 2013, 07:20:28 PM
That's a good question.  I remember asking the same one in this thread a year ago and getting a very satisfactory answer...  I am ashamed to admit that I don't remember the answer exactly but I remember that it cleared my reservations about it.
I think it concerned the field winding of the big belt driven generator.  In the third video clip, TK used a self-exciting alternator, that did not have any supply requirements for its field winding.
Is it this one?
Quote from: verpies on September 04, 2012, 07:47:16 PM
What is supplying the power to light those light bulbs when the brass disks are not spinning in this Kapanadze video ?
Also, why a little bit later, the men move away appearing agitated?
This, in my opinion, is very simple. This is actually the part that finally convinced me that the spool device is  the ultimate conversion device in all TK's demonstrations.
In this video, at first, TK is using the output of the generator/pulser part in that box to excite the internal device. Next, he disconnects the internal device and uses the generator/pulser to excite the electromechanical spool device. Then, he rewires the output of the generator/pulser again, to power the internal  device. This internal device is equipped with the pick-up coils and therefore can power the bank of bulbs. Both devices can be powered by the same generator/pulser. This, of course, implies that both, the external and the internal devices are very similar spool-type devices.
The running away can only be explained by TK mentioning the word "radiation" or similar...
Farmhand
Quote from: a.king21 on April 23, 2013, 08:54:42 AM
As for the guy "gingerly" touching the output cable which is next to a LIVE DRAIN: take a look at Tariel's patent. It PLAINLY states that the neutral output goes to ground. PLAINLY.
So wouldn't any of us treat such a cable gingerly? Imagine a 2 kw fire with the neutral connected to ground. Wouldn't any of us treat the uninsulated ground wire  with caution - in case of an internal short or malfunction? I know I would.
Yes that is true. But the point is bolting a ground wire to a concrete block makes no sense ? It is possible that the bolt is drilled and the bolt itself and the braid it bolts down on is just for show, and a real but insulated live wire could go through the drilled bolt exiting under the concrete block and connecting to whatever source of potential is desired. There could be a MOT wired to the mains down there and the active wire from the MOT going through the wire which is through the drilled bolt and in the middle of the braid. or if the braid is made of separately insulated strands some strands could be used "through the bolt" for potential and some strands to the bolt then to ground, which would give two conductors into the device.
I can draw how the bolt would need to be drilled to accomplish that if you like. Very simple, just drill the bolt from the thread end to the bolt head then drill in to that hole from the side just under the bolt head. The setup could even be worked by the one wire method using just the active with some of the braids connected to the isolated bolt in the concrete block/cover. But I think a two conductor setup would be easy to fake using a hole in the ground containing a source of potential, some braid an insulating cover for the hole and a drilled bolt.
I'll make the drawing.
Cheers
Farmhand
Has the "Trick Bolt" been ruled out yet ? There are several ways it could be used.
Cheers
P.S. I guess the words to use could have been something like. Can you lift the concrete cover so we can see what it is actually grounded to ?
Or something like that so as not to seem like a skeptic maybe.
cheappower2012
One problem farmhand,with the trick ground wire,you have to call a.king21 a liar,
since he said the ground wire was disconnected for awhile and it still worked.
Hoopy said he didn't believe a.king21, effectively calling him a liar.
In order to work hv dc or hv ac would have to come from the ground connection,the heater would have to be modified.
Since a.king21 doesn't respond to me,someone needs to ask him,did you supply the heater or did
TK supply it.Since a.king21 and company didn't measure at the plug ,we don't know,what voltage,ac or dc and if ac what frequency there was at the plug.
So this question of the ground wire, may, because of unknowns, become , I believe its fake
or I believe its real,an answer with no real proof either way.
To all:
In the video he lights the lamps,by applying
the 9 battery to start it, the disk assembly does nothing.
If he disconnects the generators internal wires and
connects the external wires in parallel,to the ones from the box,he could create the illusion
that the disk turns the generator and the generator lights the light bulbs.
The purpose of the disk assembly is to fake you out and hid the real device.
The video clearly shows no need for the disk assembly.You guys still don't get it he hides the active part,he isn't like a regular conman that creates a working device by illusion,hes devices work ,what he does is  hide things so no one can replicate it.
Farmhand
Quote from: cheappower2012 on April 24, 2013, 12:37:06 AM
If that is true it would have been a very important thing to show. Why was it not video taped ?
And if the two wire scheme was used the grid 220 - 240 could be used and things inside the box done for show.
Also if one wire HV DC or HF AC was used something in the box could have down converted it and altered the frequency if necessary.
I'm wondering why risk showing the real thing (even if you do have it), when it can be easily faked.
By hiding it with the excuse of idea security he creates the ease of fakery.
I'm not calling anyone anything. I'm just asking questions and proposing a way it could be done even with two wires.
Cheers
P.S. The motive needs to be remembered as well. Why is he doing these demo's ?
Does he ever upload video's of his own to show his stuff ?
I thought I seen it turned of a few times during the video.
