0 Members and 187 Guests are viewing this topic.
verpies
Quote from: Farmhand on April 23, 2013, 11:13:09 PM
Has the "Trick Bolt" been ruled out yet ? There are several ways it could be used.
I already was writing about the hollow bolt at the same time, that I was discussing transferring concealed power through the braid.
No due diligence was shown on the available videos to eliminate this possibility.
verpies
Quote from: yfree on April 23, 2013, 10:44:06 PM
Is it this one?
I think so.
In this video, at first, TK is using the output of the generator/pulser part in that box to excite the internal device. Next, he disconnects the internal device and uses the generator/pulser to excite the electromechanical spool device.
So you've been reading my posts for the last week and were not helping out?!
Since you are around, I've got two difficult questions for you:
Q1) Why TK's motor videos don't show a flux guiding disks made out of ferromagnetic material of high permeability, sandwiched with the brass disks ?
Q2) How can the secondary (inner rotating part) of the rotary transformer pick up the HF pulses if it is enclosed in a steel shaft that has strong shielding properties.
P.S.
The skin depth of plain steel is 60μm at 100kHz (assuming relative permeability of steel equal to 100).
Note that Q2 is not a question how the stationary primary is wound (the toroid) - we can assume a circumferential winding concealed under the ordinary toroidal winding.
Hoppy
Take a listen at 06:05 onwards on: http://www.youtube.com/watch?v=qVUN3GsekKQ
As the motor slows and comes to a stop there is a high pitched 'singing' noise. This sounds very much like the noise coming from a Bedini type motor when it goes into self-oscillation. I am still open minded between belt drive and Bedini monopole drive for this big motor device. Has anyone got another explanation for this noise?
Farmhand
Quote from: verpies on April 24, 2013, 02:20:20 AM
Oh ok then, thanks for the reply.
Cheers
Hoppy
Quote from: cheappower2012 on April 24, 2013, 12:37:06 AM
The purpose of the disk assembly is to fake you out and hid the real device.
The video clearly shows no need for the disk assembly.You guys still don't get it he hides the active part,he isn't like a regular conman that creates a working device by illusion,hes devices work ,what he does is  hide things so no one can replicate it.
Agreed. The real device / active part to light the lamps and the power supply to run the motor and power the device that light the lamps is hidden in that big space beneath the disc assembly.
