0 Members and 199 Guests are viewing this topic.
Hoppy
Quote from: verpies on April 24, 2013, 02:20:20 AM
I already was writing about the hollow bolt at the same time, that I was discussing transferring concealed power through the braid.
No due diligence was shown on the available videos to eliminate this possibility.
Your suggested method of transferring power through the braid does IMO seem to be the most likely explanation to how electrical energy is brought into the aqua2 device to power the heater. Unfortunately, without knowing what that lump of concrete was covering, it will likely remain conjecture.
cheappower2012
Hoopy
I believe that the active device powers the motor and the lamps,there maybe a big battery to start it,once started the active device  powers everything.However its hidden so its a dead end.
cheappower2012
Hoopy
Because no readings at the heater plug in the aquarium 2 video were done,its a big problem,is the voltage ac or dc,how high,what is the frequency if ac,along with a video showing the device working with the ground disconnected.This was not done because a.king21 and company  thought they had a deal with TK,without this,you can never resolve this.You either believe a.king21 tells the truth or you believe he lies about disconnecting the ground wire,hes either honest or a liar.Unless you show a physical model  powering a 2kw load  by a ground cable,its hot air ,because its critical to a theory of fraud,if no one builds it,the theory is vapor ware.If you make this I suggest you get a good insurance death policy before you start and a lot of rubber gloves. ;D
verpies
Quote from: Hoppy on April 24, 2013, 03:34:18 AM
Take a listen at 06:05 onwards on: http://www.youtube.com/watch?v=qVUN3GsekKQ
As the motor slows and comes to a stop there is a high pitched 'singing' noise. This sounds very much like the noise coming from a Bedini type motor when it goes into self-oscillation. I am still open minded between belt drive and Bedini monopole drive for this big motor device. Has anyone got another explanation for this noise?
Gidfactor noticed that noise and I already explained it.  See the quote below.
Quote from: verpies on April 10, 2013, 09:00:06 PM
Quote from: Gidfactor on April 10, 2013, 08:37:00 PM
in the first video just when he stopped the motor for the guy to take measurements I heard a hall sensor screaming to lock the rotor in to step.
Hall sensors are noiseless.  At 6:12 I heard a little LF buzz when the rotor was stopped, wires to the rotor were disconnected and the 9V battery was connected.  The high frequency screeching is typical of a belt drive at low rpm.  It is absent after the belt is removed after 14:51.
Quote from: verpies on April 18, 2013, 08:44:50 AM
Also, note that at this point in this clip, the belt on the generator pulley is taken-off and the previous belt-squeaking noises are absent.
In other words that squealing noise comes from the overt belt drive between the generator and the dual disk motor.
When this belt is taken off, that squealing noise completely disappears.
Farmhand
Quote from: cheappower2012 on April 24, 2013, 04:49:59 AM
Hoopy
Yes true, My point is that I could fake most of the Devices he shows in the type of settings he shows them in. If I could hide things in big aluminium boxes or in holes in the ground
it would be dead easy, so why the need for the free energy device anyway. I would like to see a translated version of that video. Especially between 7:00 and 11:00 minutes.
I think the most telling parts of the video was all the arguing in that period and the two suited guys laughing and whispering to each other slightly away from the others.
Please forgive my humor but in my mind the guy on the left would have said something like, ( is this fellow for real, the aluminium box could house enough batteries to run my house heheheh ).  http://www.youtube.com/watch?v=qVUN3GsekKQ
The start up noise sounds like a motor with a hardened steel disc or blade attached to it ( similar to circular saw sound ) it would not be difficult to engineer a centrifugal drive so
that when power was removed the wheels spun freely. And doing so with some reasonable amount of friction under power would allow the large flywheels to help with momentum.
So it could go like this - a large electric motor has a steel disc with a rubber or even shark toothed circumference, this entire setup could rotate slightly when loaded so that the either the rubber circumference drives a disc which in turn drives the big rotor by gears or belt, or the toothed circumference could mesh into a rubberized drive gear or something, then when power is cut the assembly swings back away and allows the big rotor to freewheel. Anything could be in the big box. Also the cover over the
bearing in it's housing seen on the right hand side or the belt side pulley mounting "box" looks sus to me.
The start up motor sounds like a motor with a hardened steel disc like a circular saw blade. Still I must ask why the need for a real free energy device if everything is hidden anyway ?
If I make a convincing enough device will people pay to come not to see most of it. I could do with the money and the work would be easy. I guess the way to do it is to start small with my own "brand" of device, get some interest and some cash then up the ante from there. To start off I might need to get some friends to act as investors paying for a demonstration and have them upload the video's. Then I can show my face and even use my real name, well I could if some forum members did not already know my real name
because of posting items to each other.
If we watch this video of Don Smith being put on the spot by the guy in the blue shirt at about 4:00 minutes in we can see he tries to intimidate the guy into shutting up with veiled threats, then just talks rubbish, he contradicts himself, and admits he is after money. This is typical behavior of a Scammer. As long as no one ever gets to actually look at everything he can fake whatever he can dream up as believable by the people he wants to deceive and there is no way of ever "outing him" if he was faking. It's a "Long Con" in my opinion..
http://www.youtube.com/watch?v=OHsEoFszeEw
Cheers
P.S. A direct friction cylinder drive can be made so that it "pulls" itself in tighter to the wheel it's driving and increase the friction, I did that when I mounted a 2.5 HP Victa 2 stroke lawn mower engine on my bicycle. When engaged the torque pulled the drive cylinder in tighter to the wheel and increased friction, (it's all about arcs and levers), steel on rubber is remarkably tractable. The bike did over 70 Kilometers per hour, very dangerous but sheer joy to pass a car on a pushbike with lawn mower power.  ;D
I've picture of it somewhere. Not to go off topic though.
