0 Members and 195 Guests are viewing this topic.
Grumage
Quote from: verpies on April 24, 2013, 04:18:36 PM
A very astute observation and a good question.  TK's motor has only one coil (for RF).  The static polarizing field is generated by a stack of ring permanent magnets on a fiberglass shaft (inside the coil).
I could write an essay about the low permeability of magnets (like air) and magnetic lines of flux repelling each other but the magnetic simulation below should substitute for it.
The magnetic field created by the green coil is not shown due to my laziness, but it would curve out of the ends of the coil and be vertical in the Gain Medium region, if the shaft has low permeability (like air or fiberglass or permanent magnets ...yeees PMs have the same permeability as air).
Dear Verpies,
Many thanks for your reply, but I was actually refering to Hoppy's favourite tin can coil!! I did not post a picture, fearing the wrath might come down on me :)
You won't forget my other questions please?
Cheers Grum.
Zeitmaschine
Quote from: Сергей В. on April 24, 2013, 04:43:05 PM
Kapanadze SOLVED !!!!!! OU selfrunning apparatus has finally came !! 500 Watts FREE POWER FOR FREE PEOPLE !!
http://www.youtube.com/watch?v=gz0IPdPbHvA
Have I missed the schematics? Or maybe we do a thorough video analysis like that tin can of TK (say additional 1000 pages). ;D
Quote from: verpies on April 24, 2013, 04:52:29 PM
The aluminum tube could be the Gain Medium in which current of charged beta particles is generated.
Could be a shielding Faraday cage as well. ;D
Сергей В.
Quote from: Zeitmaschine on April 24, 2013, 06:18:06 PM
Experiment is a mother of knowledge !! :)
ЭЫЖ: Жалуется учитель физики коллеге "Ну дочего-же дити тупые пошли, первый раз объяснил не поняли, второй - опять не поняли, третий раз объяснил, уже сам понял, а они нет" !!!! :) :)
Farmhand
Всем привет
ps: The only 1 Remaining copy on whole Internet ?? Did ILLUMINATI CABAL JEWTUBE deleted all OU VIDEOS ?? and WHY DID !!
ps: It's very easy reasearching OU principles when behind your back (Kapanadze) stay Russian Academy of Science and Secret Science Research Programs RIGHT ??
ps: Kapanadze - Have am RIGHT ?? :)
ps: Forget NMR, Radioactive Rubbish and similar things !! RUSIAN PHYSICIST NIKOLAI TESLA DID IT FOR ALL OF US 100 YEARS AGO !! QUESTION HOW SO NIKOLAI TESLA IS A RUSSIAN  MAN ??
Regarding the part I made bold in your post. Can you explain what you mean by that.
QuoteRUSIAN PHYSICIST NIKOLAI TESLA DID IT FOR ALL OF US 100 YEARS AGO
If you mean Tesla made bucket loads of free energy, then please show us the claims made by him regarding that.
This is how Nikola began his patents and is what he considered his heritage to be.
QuoteTo all whom it may concern Be it known that I NIKOLA TESLA a subject of the Emperor of Austria Hungary from Smiljan Lika border country of Austria Hungary
Video shows guy using a couple of transformers.
Cheers
Farmhand
Quote from: verpies on April 24, 2013, 09:54:54 AM
Why complicate it like this?  Remember Occam's Razor.
Wouldn't it be much less work to propel the shaft with a belt drive marked in yellow in the diagram below?
Also, don't you find Hoppy's Bedini Motor idea even simpler than that?
Yes but then the discs will not free wheel like they did. To me they did not seem to be belted (EDIT: to a drive motor) unless belts are tight they slip and cause drag when tight.
With a swing in drive assembly the rotor free spins once power is removed and would be silent. If there was a belt inside the device driving the rotor
one would be able to feel the belt when the rotor is moved by hand. EDIT: I mean if it was attached directly to a drive motor. A swing in friction drive could be very simple to make.
The main point is there is enough room to hide a butchered steer in the aluminium box. Anything could be in there. It's not a demonstration it's an insult.
I don't believe the toroid does anything much.
Cheers
EDITED:
