0 Members and 91 Guests are viewing this topic.
Thaelin
   Since I am just a reader and an occasional dabble with it, this is worth just about 1/4 of a cent.
This refers to the L4 and what it is to do. This is a series LC resonator. Resonator. That tells me its
job is to tune the two larger coils to a specific frequency and block the others.
   Going on that, what is the average frequency of the driver? You will be sending the L1 this signal
which will then be the base frequency. That frequency will not be right for the two large coils most
likely as each build will be different. Just a way of tweeking it. Saying that, I would expect L4 to be
in the same direction. If wrong, not hard to swap it if wires were into a block.
   So with that Grum, I would say you are not in the top of the resonant curve so therefore the
impedance it sees is way too high to pass any appreciable power.
I remember building my induction heater just for the heck of it. It was about 38k when it got warmed
up and going. Did have the caps get hot tho. Had to put on some huge honkers out of MV ovens to
handle it. Ran on at about 1.2 amps if nothing in the coils and up from there. Did this have a slug
in the center of the AL pipe, hmmmm have to re-watch that vid and see.
thay
FreeEnergyInfo
free energy ????
www.realstrannik.ru/forum/39-kapanadze/108060-generatory-kapanadze-obshhaya-tema.html?limit=18&start=2106#127363
semenihin-77
Сегодня хороший день, пойман интересный эффект  ;D
Today is a good day, caught an interesting effect  ;D
Два варианта одной схемы, на 10 вольт переменного напряжения и на 20 вольт переменного напряжения.
Two variants of a circuit 10 volts AC and 20 volts AC voltage.
Теперь я знаю откуда такой звук при включении "Аквариума"
Now I know where the sound when the "Aquarium"
http://www.youtube.com/watch?v=JCOEjb0Ag_I
Hoppy
Quote from: semenihin-77 on May 01, 2013, 11:10:59 AM
You have me interested with that video, as the sound is just like that on the Aqua1 and Green Box garden videos. I see what looks like a ferrite cored flip-flop circuit, some caps and a transformer. Can you find out more about this setup?
semenihin-77
В схеме есть деталь на первый взгляд неважная, но без нее не работает . Этот эффект пойман случайно, в жизни не подумал бы что это так может работать, а сама схема простая, катушка состоит из 3 и 6 витков всего.
The circuit is part unimportant at first glance, but without it does not work. This effect is captured by chance in life would not have thought that this can work well, and the circuit is simple, the coil consists of 3 and 6 turns only.
