0 Members and 41 Guests are viewing this topic.
stivep
For anyone who want to contribute
Sources to visit:
For Colman Formula
http://www.rexresearch.com/colman/colman.htm
https://groups.google.com/forum/?fromgroups=#!topic/sci.chem/7G8tBn7xn6c
http://www.varioustopics.com/chemistry/423024-re-3ca-po3-2-10c-story.html
http://www.molecularstation.com/forum/chemistry-forum/24062-3ca-po3-2-10c.html
http://www.answerbag.com/q_view/1268727
http://www.overunity.com/844/amazing-nuclear-power-converter-via-oscillating-tank-circuits/15/#.UYFqBLVQGHs
http://books.google.com/books?id=JAkPAAAAYAAJ&pg=PA120&lpg=
PA120&dq=3ca(po3)2%2B10c&source=bl&ots=o5jlRbTaKz&sig=
YIoumw17N3KE5pk_aDWflSxoWmE&hl=en&sa=X&ei=
xGeBUYSNLc2n0AHMg4GYDQ&ved=0CFkQ6AEwBg#v=onepage&q=3ca(po3)2%2B10c&f=false
http://www.webqc.org/mmcalc.php  start with Ca no with 3Ca(PO3)2 to  calculate . so you put Ca(PO3)2 to the window to have rough  representation
http://books.google.com/books?id=WwzyAAAAMAAJ&pg=
PA767&lpg=PA767&dq=3ca(po3)2%2B10c&source=bl&ots=0AXF-S_tZD&sig=5Ijbx-HIcP1pTiaE6cKMzrya7Ho&hl=en&sa=X&ei=xGeBUYSNLc2n0AHMg4GYDQ&ved=0CFwQ6AEwBw#v=
http://books.google.com/books?id=Vou0NZJhBE4C&pg=
PA812&lpg=PA812&dq=3ca(po3)2%2B10c&source=
bl&ots=2SmbzaXRIx&sig=gFj4vgU-GCCaQsv1aVSEXiEYTbY&hl=en&sa=X&ei=
xGeBUYSNLc2n0AHMg4GYDQ&ved=0CF4Q6AEwCA#v=
http://books.google.com/books?id=LF8XAQAAMAAJ&pg=PA147&lpg=PA147&dq=3ca(po3)2%2B10c&source=
bl&ots=d2syPlQJyP&sig=MLcuGggxJMgy6HE9WklBHw4L6Iw&hl=en&sa=
X&ei=xGeBUYSNLc2n0AHMg4GYDQ&ved=0CGEQ6AEwCQ#v=onepage&q=
http://forums.futura-sciences.com/chimie/190462-formule-3ca-po3-2-10c.html
http://www.chemindustry.com/chemicals/056691883.html
From what I see the formula is  possible to  obtain.
Please do the rest on your own .
Contact  Chemistry guru on forums
Post it i here
Wesley
Hoppy
Quote from: Grumage on May 01, 2013, 02:18:05 PM
Dear Verpies,
Yes it would appear so!!! Any idea why the setup works so much better with a Switch mode bench power supply than with a battery?
I have now got L4 completely disconected. Using a 12 V battery to drive Royer and 2 earth connections, one at Ground side of 3 turn primary. Earth 2 at isolation transformer L3 leg, I have a dim light.
Non of this makes any sense to me as the other end of L3 is open circuit.
Cheers Grum.
Evening Grum,
It looks like you have induction into L2 with a direct path back from the lamp to the ground side of L1, so I think you should see some illumination.
Grumage
Quote from: Hoppy on May 01, 2013, 04:24:21 PM
Evening Grum,
Good evening Hoppy.
Cheers for the reply, this device is insane it keeps throwing things at me. Since last post I laminated a sheet of Baco foil HD and brought out a tab. I sleeved this into the tube and saw more light.
But please try out my idea with the Royer. I know Verpies has dismissed it as a simple transistor transformer but I think there is more to it!!
I have also been trawling the web with regard to the similarities between this device and the Hendershot generator and it would appear that L4 should have "exactly" 1/4 the length of wire that L3 was wound with.
But as I said the most perplexing thing is why the device shows a much better performance with the Bench PS than with a battery???
Regards Grum.
Hoppy
Quote from: Grumage on May 01, 2013, 05:06:03 PM
Good evening Hoppy.
Regards Grum.
Grum,
thanks for your update.
The Royer oscillator shown replacing the two transistor flip-flop in post 17297 is driving a flyback which in turn drives the spark gap but I don't think this is a TV type flyback coil and probably more powerful.
When powering your setup with a bench supply and getting a bright lamp, is the circuit as shown on the schematic or have you connected the other ground to the L3 leg to T1?
I'll do some experimentation with a Royer osc on the front-end.
stivep
    I.m going to be posting something that you not talking about  recently :
    But Verpies if you find the time could  you please analyze it disregard the fact of its sense on nonsense
    Please do not concentrate on uranium or take uranium as possible example ( Video) - it is  important to see it  as mechanism....................
    and as the same  mechanism for Colman compound as well.
    energy-dispersive x-ray spectroscopy (electron microscope analysis) of uraniu
http://www.youtube.com/watch?v=B51hos0DUpk
start from minute:5:00 of this video.
http://www.tau.ac.il/~lab3/XRF/xrf.pdf   LOOK FOR "Auger" Electron
If electron is dispersed depends of energy level due to x-ray ( SPARK OF  TK IS OUR  XRAY source but any  ion chamber  even in  coil capacitor  due to high voltage  )
Depends from the  fact  that  it might be  as energetic to go to core of an atom or less energetic to play with K orbit of an atom   and/or affecting valance electron
We are dealing in physical  hole in that atom structure- that hole is than filled  with  electron fro different orbit.
As electron from higher orbit has  higher energy level than  it losses energy  in quantum when it files the  hole.
We are than dealing  with relaxation - but as energy must be conserved than whatever is atom manifestation  from outside
it is  energy.
(Most of the times  when electron loses its orbit produces photon= energy= no mass. and energy is  huge.)
Than makes  atom to produce at  minimum Xray back  at maximum Beta. Gamma.( I'm not sure  if  Neutron ..well if it hits nuclei.) everything depends on energy  level of "destructive" hit.
could that be applied to ferrite, even to copper ( yes)( could we deal with NMR at the same time  as well?- why not)
That energy from atom as it is in unstable stage  is than affecting coil capacitor of TK
That rood that I was pointing in  TK  video Aquarium- steady state generator)
Capacitor than will be charged, If than discharging and coupling  circuitry is design  part of that energy is returned back to sustain  instability of  a compound if thatr  compound is  to be found in TK device.
But if it is not than we have non TK   concept.
I'm waiting for  XRF  spectroscopy analyzer that should  arrive shortly to my location.
It is 100% help from seller who decided to give it to me instead of sale it  to me.
It has all software and hardware and photo multipliers and cells 2 ribbon  cables have been chewed by  unfriendly creatures
Color  screen and 3D representation.
The importance of it is in fact of recording changes in compound  as  additional prove of transmutation and
will give me  chance to look close  in to compound used in general.
I'm also hunting for another one we will see if I would succeed That one is 240k new  using cryogenic
high purity germanium detector  I have chance to cut a deal similar to previous one.
The result might be to assign chemical   parameters to no doubt for its repetitiveness
One might ask why I'm going to so much trouble hunting Colman.
Answer:
I have seen it acting and reacting.
energy-dispersive x-ray spectroscopy (electron microscope analysis) of uranium minerals - YouTube
www.youtube.com
xray spectrometer - YouTube
www.youtube.com
X-ray Electron Spectroscopy / Auger Electron Spectroscopy - YouTube
www.youtube.com
X-Ray Photoelectron Spectrometer Tour by Roy Murray - YouTube
www.youtube.com MESSENGER's X-Ray Spectrometer (XRS) [720p] - YouTube
www.youtube.com
X-Supreme8000 XRF (x-ray fluorescence) spectrometer for materials analysis used in quality - YouTube
www.youtube.com
X-Ray Photoelectron Spectroscopy (XPS) training through MRFN.org - YouTube
www.youtube.com
MRFN.org - YouTube
www.youtube.com
SIMS training through MRFN - YouTube
www.youtube.com[/li]
[li]
XPS Analysis through MRFN - YouTube
[li]
X-ray Fluorescence Spectroscopy - YouTube
[li]
Bragg Spectrometer, Bragg's Spectrometer Method, Working of Bragg Spectrometer - YouTube
[li]
                           The MIDEX Micro X-Ray Fluorescence Spectrometer from Spectro - YouTube
[li]
What is X-ray Spectroscopy? - YouTube
[li]
https://www.google.com/search?q=spec...1096& bih=582[/font][/size]
Colman Beta Decay, New Energy Source
www.energeticforum.com[/li]
[li][/li]
[/list]
Wesley
Most of these  are  cheap but because it is no software for it and they are no color  even if model is the same. without manual and software it is nonsense to buy it as you get nothing out of it.
Most of them are not working one if not all of them.
I have got the most newest one from  that series. Actually I do not see  3D in  software here but  I look closer I have  just  got it.
Yes 2 ribbon cable are chewed  but that is ok.
It takes some really thinking  to find how to use flow spectrometer and adapt it to  my needs.... well doable
