0 Members and 586 Guests are viewing this topic.
Ros-Co.
A very basic OU transformation experiment.  A MOT parallel with an 1uF cap.  It easily draws a 2KW halogen lamp.   The input voltage only 150V on the MOT primary.
http://www.hvlabs.hu/zpe/rotoverter/TV/MVI_5622.AVI
A spark gap transforms the high voltage into useful current.  It's a known effect, but the type of the waves transformed (longitudinal waves) which is more efficient than Hertzian waves. It seems OU.
It's a trick of transformation.
Be careful with spark gap, it produces a very wideband RF radiation (and in ZPE band) which is harmful. Not just The UV!
xenomorphlabs
Naudin´s device has only the input side and the fact that he merely uses an additional ground (which Kapanadze and SR do not have) in common with Alexander Frolov´s schematic.
The difference in Naudin´s set-up is that his LOAD (нагрузка)  is IN SERIES with the earth grounds and the secondary which is in keeping with how Kapanadze has connected his LOAD only that he uses one ground.
SR (and maybe also Kapanadze) also creates a sine wave LV signal with a transistor pair and Naudin´s seems to make use only of the HV part.
Eighthman
Please forgive me if this is redundant but reading thru 117 pages can be difficult, so I did a search and didn't see the name "Prentice" come up in this discussion.
The Prentice patent looks very similar.
http://www.rexresearch.com/prentice/prentice.htm
dutchy1966
Quote from: Ros-Co. on June 06, 2010, 09:27:45 AM
Yes this is what Tesla was doing. In adding a strong magnetic field to "blow out" the sparc he was trying to stop electrons from jumping the gap.
To me it seems as if the longitudinal waves drag some of the free electrons with them (on the surface of the wire).
According to "free energy secrets of cold elecrtricity" the "gaseous flow" which gets seperated from the charge carriers (electrons) at the spark gap, seems to be able to produce (free) current in other metal objects (wires).
exnihiloest
Quote from: baroutologos on June 05, 2010, 07:33:00 PM
Why he posts videos and photos of bulbs lit and does not presents schematics and principle of operation?
I asked me the same question. It is unusual.
There is also something boring me: the grey grid cable on the right, with plugs.
