Grumage
Dear Hoppy.
I still can't leave the Chibinidze replication alone for long. I put it away then get it out again!! Today it dawned on me to try something that dear Verpies would probably have done at the outset!!
I connected my trusty old SG via a 1K ohm resistor to the 3 turn primary and then looked for a resonant responce at the output. And guess what? Bingo, at about 1.04 Mhz there was a real gain in signal strength. So I re tuned the Royer and blasted my last pair of Mos-fet's!! Thank goodness for Farnell, 30 in the post for tomorrow. So I am still in the dark, pardon the pun!!  :)
If you still have your replication to hand, would you be able to try the same? Perhaps verifying my results? I had everything connected, even the 40 W bulb.
And Dear Zeitmaschine I have put my output transformer in an earthed sweet (candy) TIN, just for you....... 8)
Cheers to one and all, Grum.
Hoppy
Quote from: Grumage on May 13, 2013, 12:45:36 PM
Dear Hoppy.
Evening Grum,
Yes, I will re-assemble the device but please refresh my memory by posting a schematic showing where you have placed the ground connections as I assume you are still not connected as per the original schematic. I will need to find another flyback as I stripped down the only one I had to get the ferrite core out for the last experiment!
guruji
Dear Hoppy.
I did an aluminium on the resonant coil but still cannot get anything out of this setup. Wondering why ::) .
Grum can you please tell me how much resistance you have on resonant coil?
Thanks
Grumage
Quote from: Hoppy on May 13, 2013, 02:10:51 PM
Evening Grum,
Evening Hoppy.
You will not need your HT Flyback for this test. Just remove any connection you have to L1 (3 turn coil) inc ground. Apply SG via 1K ohm resistor to drive primary L1. And place Scope to output (24V) of T1.
For me unfortunately my SG runs out of "puff" at 1.1 Mhz. I am going to invest in a new scope and SG pretty soon. BTW my SG has an output of 12V p/p.   But you should see a resonant  responce. I now have the circuit as per original schematic.
Once you can see a signal gain, try earthing different spots of the circuit. For me, like the video showed, a major gain in signal output is achieved by earthing one of the series connected 1 micro farad MWO caps!! I don't think that a few milli volts input would create a field sufficient to radiate??
I am going to post the schematic seperately, because every time I have tried in the past it fails security and I don't want to have retype this message again!!
Cheers Grum.
Grumage
