0 Members and 223 Guests are viewing this topic.
Hoppy
Quote from: Grumage on May 13, 2013, 04:03:40 PM
Evening Hoppy.
You will not need your HT Flyback for this test. Just remove any connection you have to L1 (3 turn coil) inc ground. Apply SG via 1K ohm resistor to drive primary L1. And place Scope to output (24V) of T1.
For me unfortunately my SG runs out of "puff" at 1.1 Mhz. I am going to invest in a new scope and SG pretty soon. BTW my SG has an output of 12V p/p.   But you should see a resonant  responce. I now have the circuit as per original schematic.
Once you can see a signal gain, try earthing different spots of the circuit. For me, like the video showed, a major gain in signal output is achieved by earthing one of the series connected 1 micro farad MWO caps!! I don't think that a few milli volts input would create a field sufficient to radiate??
I am going to post the schematic seperately, because every time I have tried in the past it fails security and I don't want to have retype this message again!!
Cheers Grum.
Grum,
I get a peak at around 1.3MHz. My SG was set to max amplitude at 26V P-P.
guruji
Quote from: Grumage on May 13, 2013, 04:24:53 PM
Dear guruji.
Good to read you are pursuing this device. My "current" L4 is wound on a 25mm dia plastic tube long enough for me to move it up and down within L2/L3. It has 11 feet (3.1 metre approx) of 23 AWG enamelled copper wire. It's resistance is 0.153 ohms. BTW I posted all resistance and inductance measurements for my device on reply 17346.
If you have the equipment try looking for your resonant "sweet spot" as I have recently posted to Hoppy. With this data we may be able to breath some life into this device.  :)
Cheers Grum.
Thanks Grum. My resonant coil is a bit long it's about 17ohms. I will try another shorter and see. Today I checked how fast a cap charges with the cold electricity from the resonant coil but was not that impressed.
Maybe caps have to be conditioned to adjust for fast charging.
Anyway will see.
Thanks
anandml
Quote from: captainkt on May 14, 2013, 05:36:07 AM
Hi,could someone please translate a few parts of tungus diagram. looks interesting, after all it is so simple you will laugh . Looks as if only small load from house transformer.
Tungus diagram translation...
You need a very fast diode to charge a cap effectively with high frequency pulses or HF AC ("cold electricity"). I like MUR1560 for speed and high-current capability, but others, like from TV chassis, can also be used. Experiment, compare the voltage and time-to-charge that you get in the cap with different diodes, you'll see what I mean.
