0 Members and 138 Guests are viewing this topic.
turbogt16v
to grum
http://www.imagebam.com/image/874026254538381  so is this the setup for the coil
and through it goes aluminum or coper pipe cat on one side that is not connected to anything in the circle
to TinselKoala
is diode MBR20200CT: 200 V, 20 A Schottky  god for the circut
Hoppy
Quote from: TinselKoala on May 14, 2013, 09:11:55 AM
You need a very fast diode to charge a cap effectively with high frequency pulses or HF AC ("cold electricity").
Are you referring to a particular circuit in this thread or is this just a general statement?
I like the DSR15V600 trr 23-30nS. Even better the IDH12SG60C thinQ!
sparks
     I believe what happens in a spark gap or partially evacuated vacuum tube is  called inverse compton scattering.  This blueshift of the incident photons can be simply described as realitivistic electrons (bound state where the uncertainty principal predicts a very high electron velocity} being cooled.  I am aware that quantom states of the electron are limited to the very small but realitivistic electrons appear to reside in both classical and quantom mechanical states.  Simply put photon goes into atomic field of influence and leaves at a higher frequency then when it went in. This is at the expense of the electron kinetic energy of the bound state electron.  Where did the excess energy come from?  Photon for example with a frequency of 1nanometer is blue-shifted to .1 nanometers.  This is an increase in energy carried by the photon at the expense of the kinetic energy of the bound state electrons if you ask me.  These little devils have inertia and when it is altered out pops a photon.  Now it becomes necessary to collect the photons and power up an antennae with rf currents and transform these currents into low frequency currents.  Not easy.  One thing I read about Tesla's experiments is that the interruptor geometric placement to the large shunts feeding the sg was important as well as the length of the shunts.  What I believe was going on in this case was that low frequency photons were being generated by the spark gap and being converted to rf currents in the shunts.  The energy building up in the system at the expense of the atoms flowing through the gap.
    I often wonder if the kinetic energy of a bound electron has ever been converted to joules?  Then I could get a handle on ionizing radiation energy invested versus potential kinetic energy available in bound state electrons.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumage
Quote from: Hoppy on May 14, 2013, 06:01:53 AM
Grum,
I get a peak at around 1.3MHz. My SG was set to max amplitude at 26V P-P.
Dear Hoppy.
So you are quite close to my resonant frequency of 1.04 M Hz.
Well what do we do now? Drive it with an oscillator and see what happens?? Might it just work?
Mos-fet's failed to be delivered so will have to go and get them later on. Will see if anything happens?
Cheers Grum.
Grumage
Quote from: turbogt16v on May 14, 2013, 09:30:39 AM
to grum
to TinselKoala
Dear turbogt16v.
That is the more complicated schematic. Both Hoppy and I are working with my post  Reply #17519 please ignore LHS coil configuration.
The only Diode in the circuit is for half wave rectification of the HT circuit. Both Hoppy and I have exhausted the notion of this actually being able to drive the circuit. Findings have recently been posted that the resonant frequency is about 1 MHz.
Cheers Grum.
