0 Members and 133 Guests are viewing this topic.
grizli
Quote from: iflewmyown on June 05, 2010, 06:48:23 PM
It looks like Naudin is using a variable frequency motor drive unit for the input to save winding the coils to a particular frequency. Does anyone have any info on this unit? The only marks I can read are {  ATV3  } . Thanks
Garry
why than it looks like simple variac, or variable autotransformer  ?
e2matrix
Quote from: cgx on June 06, 2010, 03:23:04 PM
Hi FatBird,
Not knowing for sure what the rod or whatever it is that seems to go through the coil is, I would not conclude that your modified circuit is the same. I do not really understand the circuit myself. It is just how it looks to be wired looking closely at the pictures posted on jln site.
Another pic I found from the hvlabs shows what appears to be a iron or ferrite rod? going through the middle and that rod has a small coil wound on it:
xenomorphlabs
Quote from: e2matrix on June 06, 2010, 03:52:10 PMI saw one there showing 27 watts in with 460 watts out.  About 10 light bulbs running off what appears to be a 12 volt 7 Ah battery all built into an old PC power supply.
http://www.overunity.com/index.php?topic=7679.msg235580#msg235580
e2matrix
At the risk of repeating something here that may have already been found I'm going to summarize what I just found in case it may have been missed as this relates to the coil in the middle.  You have to use “kick” in the TK coil but because voltage on the ends of the Tesla style amplifying coil will be equal to zero you need to make a NON-uniform magnetic field.  To accomplish that you need a “kicking” coil off center from the amplifying Tesla style coil.
