0 Members and 156 Guests are viewing this topic.
verpies
Quote from: stivep on May 15, 2013, 11:17:54 AM
I stated that RF excitation is violation of  Forbidden transition.
Based on this video forbidden transitions  something that should not happened  but has happened
Yes, it should not have happened.
I cannot explain it using the legacy model of the nucleus but I can make some progress using Miles' model of the nucleus.  See here and here.
When analyzing this problem, it is important to notice that free neutrons are unstable outside of nucleus (they decay in ~15min into a proton and a fast electron*).  This begs the question: "what makes neutrons stable inside some nuclei" ?
I think the most sensible answer to this question is that inside the nuclei the neutrons are shielded by the protons from the hostile environment outside and this shielding is highly dependent on mutual orientation of nucleons' spin axes.  See the attached animation of an Argon atom.
Any alteration in orientation of one nucleon's spin axis in respect to the other nucleons, can expose the neutron and make it vulnerable just like outside of the nucleus.  This axis alteration is known to occur by RF in Earth's magnetic field (or in an artificially generated magnetic field).
I think that twisting the spin axis of one of the neutrons (or the surrounding protons that shield it) can expose it and violate all the known decay rules (especially if the axis is twisted by 90deg. pulse like here).  This is most likely the reason why your Colman tube is the most sensitive when you "pulse your microphone".
* According to Miles, the emission of the fast electron happens as a result of neutron's collision outside the nucleus with a slow electron/positron, which causes the complete reversal of neutron's outer spin (it has 4 of them) and its conversion into a proton.  This spin cancellation can happen perfectly only when the spin axes are aligned and that is the reason why beta particles are emitted predominantly from the polar regions of the neutron or polarized nuclei.  The experimental evidence of Beta-NMR spectrometry confirms this directional correlation.
stivep
Copy of my article in Realstrannik:
http://realstrannik.ru/forum/19-svobodnaya-energiya/122193-sekret-polucheniya-energii-collman-kapanadze.html?limit=18&start=36#130553
Quote[quote="deltasoft" post=130509]to stivep
Стив, обрати внимание, на 27:44. Росси получил в итоге 10% медь, кобальт, цинк и железо.
http://www.youtube.com/watch?feature=player_embedded&v=ldyUK5ilHjE
[/quote]
http://www.youtube.com/watch?v=ldyUK5ilHjE
minuta 25:58
Exactly the same  is happening with Colman ( using  Cobalt)
the only difference is that  Colman is  from 1956 and is free to use without any patents at all.
If someone from   Russia would  experiment with it that  will be more fast way to  make free electricity than I do  here is USA.
Russians ( knowledge base)are much more advanced than me.
And  They  can get electricity in pure form  without converting heat to electricity.
I state that Colman was using 2 processes
1. direct electric extraction
2. heat as waste associated  with the process.
Andrea Rossi uses only heat  and heat conversion as he is afraid to go straight.
That is why he uses hydrogen....
Medium is not important but process is important.
What I do i  1 month
Russian can do in 1 day.
Wesley
minuta 25:58
Точно то же самое случается с Colman (использующий Кобальт)
единственная разница - то, что Colman является с 1956 и свободен использовать без любых патентов вообще. Если кто - то из России экспериментировал бы с этим, которое будет более быстрым способом сделать свободное электричество, чем я буду делать здесь в США.
Русские (база знаний) намного более продвинуты чем я. И Они могут получить электричество в чистой форме, не преобразовывая высокую температуру в электричество. Я заявляю, что Colman использовал
2 процессa.
1. использование прямого электрического извлечения
2. используя высокую температуру, поскольку трата связалась с процессом.
Андреа Росси использует только высокую температуру и преобразование высокой температуры, поскольку он боится идти прямо. По этой причине он использует водород.... Среда не важна, но процесс важен. Это, что я делаю в период 1 месяца, российские люди, может сделать через 1 день.
нет ничего, Вы должны думать. Состав (порошок) находится в Патенте Colman
https://groups.google.com/forum/?fromgroups=#!topic/sci.chem/7G8tBn7xn6c
http://www.varioustopics.com/chemistry/423024-re-3ca-po3-2-10c-story.html
http://www.molecularstation.com/forum/chemistry-forum/24062-3ca-po3-2-10c.html
http://www.answerbag.com/q_view/1268727
http://www.overunity.com/844/amazing-nuclear-
power-converter-via-oscillating-tank-circuits/15/#.
UZO8-LVQGHt
http://books.google.com/books?id=JAkPAAAAYAAJ&pg=
PA120&lpg=
PA120&dq=3ca(po3)2%2B10c&source=
bl&ots=o5jlRbTaKz&sig=YIoumw17N3KE5pk_aDWflSxoWmE&hl
=en&sa=X&ei=xGeBUYSNLc2n0AHMg4GYDQ&ved=0CFkQ6AEwBg#v=onepage&q=3ca(po3)2%2B10c&f=false
http://www.webqc.org/molecular-weight-of-Ca(PO3)2.html
http://books.google.com/books?id=WwzyAAAAMAAJ&pg=PA767&lpg=
PA767&dq=3ca(po3)2%2B10c&source=bl&ots=0AXF-S_tZD&sig=5Ijbx-HIcP1pTiaE6cKMzrya7Ho&hl=en&sa=X&ei=xGeBUYSNLc2n0AHMg4GYDQ&ved=
0CFwQ6AEwBw#v=onepage&q=3ca(po3)2%2B10c&f=false
http://books.google.com/books?id=Vou0NZJhBE4C&pg=PA812&lpg=PA812&dq=3ca(po3)2%2B10c&source=
bl&ots=2SmbzaXRIx&sig=gFj4vgU-GCCaQsv1aVSEXiEYTbY&hl=en&sa=X&ei=xGeBUYSNLc2n0AHMg4GYDQ&ved=
0CF4Q6AEwCA#v=onepage&q=3ca(po3)2%2B10c&f=false
http://books.google.com/books?id=LF8XAQAAMAAJ&pg=PA147&lpg=PA147&dq=3ca(po3)2%
2B10c&source=bl&ots=d2syPlQJyP&sig=MLcuGggxJMgy6HE9WklBHw4L6Iw&hl=en&sa=
X&ei=xGeBUYSNLc2n0AHMg4GYDQ&ved=0CGEQ6AEwCQ#v=onepage&q=3ca(po3)2%2B10c&f=false
http://forums.futura-sciences.com/chimie/190462-formule-3ca-po3-2-10c.html
http://www.chemindustry.com/chemicals/056691883.html
http://www.energeticforum.com/renewable-energy/13901-colman-beta-decay-new-energy-source.html
http://www.rexresearch.com/colman/colman.htm
http://www.rexresearch.com/colman/GB763062A.pdf
согласно американскому закону я могу дать совет людям, чтобы играть с этим,
мое юридическое утверждение должно быть : Вы Никогда не касаетесь этого,
Вы Никогда не играете с этим
утверждение, которое не связано с первым - HAAAAAAAAAA HAAAAAAAAA HAAAAAAA
Уэсли
NickZ
   "If someone from   Russia would  experiment with it that  will be more fast way to  make free electricity than I do  here is USA.
Russians ( knowledge base)are much more advanced than me."
   Akula is saying that electrogravitics, "it does not go there".
  Wesley is saying that he knows, how the Akula device works, same as Colmans, same as TKs, and that the Wesley team have the only working schematics, etz...  What is the truth???
IF you don't KNOW, for sure, why say that you do, revolution, save the world, etz... wishful thinking, maybe?
guruji
In the Chibinize vid there is another circuit to the trafo. Wondering what could that be.
An inverter maybe for stabilizing frequency  :-\
Grumage
Quote from: guruji on May 15, 2013, 02:41:25 PM
Dear guruji.
Would you be so kind and provide link with time index?
Cheers Grum.
