0 Members and 141 Guests are viewing this topic.
sparks
Quote from: Shokac on May 20, 2013, 07:54:45 AM
NEW STAF!
New and constructive solution in the field of aggregates that produce electrical energy which provides: a cost-effective, self sufficient production of electrical energy which is eco-friendly, reliable, inexpensive, easy to use etc.
Compared to others generators it produce electrical power with no use of any kind of fuel. It can be assambled for production unlimited amount of power anywhere. It can be also used as a autonomous power source for electrical cars or other viacles which in this case dont have to be stoped for recharging.
The power unit operates as follows: poles (2) and (3) are fixed (welded) onto a base (1) and a DC generator (16) containing a transmission belt (9) is attached to the carrier (19); next the DC electrical motor-generating unit (15) is connected to the transmission belt (12); the converter (17) and the DC load (21) is attached to the pole (2); a battery (14) is placed on the base plate (20); fly-wheel (7), transmission belts ( 8) and (11) and bearings (5) and (6) are mounted on the shaft (4). The power unit works when one  switches the on button (24); cable (23) transmits the energy from the battery (14) to the electrical motor (15) which then starts the transmission belt (12) through the use of the belt (13) and the transmission belt (11); this starts the shaft (4) with the transmission belt ( 8) and the fly-wheel (7); the belt (10) then starts the generator (16) through the use of the transmission belt (9).  Cables (28) and (29) transmit the energy from the battery (14) to the converter (17), which converts the direct current to the alternating current which then travels to the load (33) through the use of the cable (32).
VIDEO:
http://www.youtube.com/watch?v=BEJsXRS4Wnw
Motor driving a generator charging a battery that drives the motor.   Youve got to be kidding.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Hoppy
Quote from: sparks on May 20, 2013, 09:01:34 AM
Not according to Bedini - Watson Machine  :)
T-1000
http://www.youtube.com/watch?v=Fv53K9MnDuM and many others.. ;)
As far as I personally understand they work on forces of leverage while smaller rotor of motor drives larger rotor of generator which is running in normal mode on slower revolutions per second - http://en.wikipedia.org/wiki/Lever
stivep
Quote from: T-1000 on May 20, 2013, 10:51:17 AM
I agree.
There is however something in addition to it:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magearth.html
factor  you adding to dynamo is electric field component.
However I have concept ... even more advanced
As you can not  alter magnetic  field of the earth>> you can influence electric field with it using angle of rotation.
related fields which are denoted by the symbols B and H. and being  90 degrees in angle one next to  the  other.
If compass  is using needle  of uneven non balanced flywheel  than inertia is directing it  to unstable stage.
By that token there is tendency to go into the balance.
This is first weak interaction in near field as we never will deal with far field.
look for  description of
near field
far field
in  wikipedia,
It is the same effect that is pointed by Arunas (look at http://en.wikipedia.org/wiki/Lever)
QuoteMagnetic fields are produced by moving electric charges and the intrinsic magnetic moments of elementary particles associated with a fundamental quantum property, their spin. In special relativity, electric and magnetic fields are two interrelated aspects of a single object, called the electromagnetic tensor; the split of this tensor into electric and magnetic fields depends on the relative velocity of the observer and charge. In quantum physics, the electromagnetic field is quantized and electromagnetic interactions result from the exchange of photons
Again we end up with  nuclear magnetics.
if in  a given geographic location A telluric current is present (http://en.wikipedia.org/wiki/Telluric_current
than we are adding electric component of its own.
By Rule :there  electric  field in conductor must create 90 degrees shifted  Magnetic field.
The good thing about it  is that:
Whenever  we are deal with DC excitation converted to  AC from  the other motor than we must have alteration  coming from AC to  primary DC exitant inducing  AC component on the same winding.
There is proven fact in macro scale of
Quoteinteraction between Earth's magnetic field and the interplanetary magnetic field
By that we  might assume that this interaction must be present  in any scale  at any level  starting from single  nuclei.]
As perpetual motion was proven by polish- american professor in Time Crystal
Video & Audio: Frank Wilczek. Time Crystals - Metadata
http://sms.cam.ac.uk/media/1228390
We are no longer dealing with  science resistance in this area .
The wording in this video stay about  Frank  statement that shift might  be present in any direction when  perpetual motion is reached
So he  does not deny shift  towards overunity.
Again energy must be conserved.
would that be geometry break as Frank implies or any other factor.
I stay that  material from the video has merits and needs to be  analyzed.
I have got similar answer from Akula about 1986 in Russia - very same project.
As my statement of today I have refused  on my part to discuss with him technical aspects of his device as I'm who I'm...
and I want to stay uncorupted  as I was before.
I need cooperation not invasion in human relation.
I understand  that many of you will be disappointed.
I do not care at all.
given is accepted only when given with the willingness................. of  gift
Wesley
br549
To Anyone:
I don't know a lot about the math and physics of the TK Device but have been following the yolk device with interest. I have done several builds, with minimum results.
My question is: what manufacture, model, and vintage Russian televisions have the proper yolks? I read the previous work starting around page 500 - forward -- got a part# but couldn't find a manufacture, vintage, or model of television. It's very possible I may have missed it :-\. Can anyone help me with this info :).  Thank you:
