elementSix
Thanks for the INFO TK, Cepra ect...  Appreciated..
As fucked up as the EVIL ALIENS theory goes.  I have come to that very conclusion.  Only that I can't see that humans would do everything they can to destroy our future.  Our race and all species on the planet are being destroyed, with little hope of recovery.  Simple things that could be fixed.  Like using HF to turn fuel into plasma.  So it pollutes 98% less would help out our AIR quality so much.  But refusing to do so, who benefits in killing off the planet, and burning the Rain Forest down.  Our last great filter and oxygen creation Zone that's left.  TESLA made Ozone generators, why aren't we using them to rebuild our atmosphere??  Its not a complicated process.  Just simple things we can do, that we won't..  Who Benefits??  GOD help us Help ourselves..
Сергей В.
Ok let't go back on work.
I have got this schematic of possible Akula Generator. I don't know does it work of not or does this schematic his or not !!
The main problem here is understanding of basic physical process involved. Once we got it we can make billions of Generators. So we are looking for Principle.
Real problem is tuning because ferrite cores and bifilar windings are really heavy nonlinear components which working proint is in strong dependence of exciataion way and sequence of excitations. We need precise dynamic excitation sequence to discover and finnaly understand the Prinicple(s)!!
Below are two schematics of genarators on PCM TL494. Can be usefull if you have that component. About Ferrite cores i suggest to test on all posssible Ferrites which you can find from old TV colour sest especially very old one with Vacum Tube lamps till the newest which you can find in microwave ovens and multisync monitors.
Oscillographs and signal generators are quite indispensable here. Try to get something like this.
For proper Ferrite core power impedance matching in complex R+-jX domains Vector-Signal-Analizer (VNA) is unchangeable. StiveP got it so he can do it if he want.
ps: I have some suspicious that the ">hocus-pocus " is not in ferrite cores but in something else. Tesla didn't used ferrites, Donal Smith also, Dally also. Maybe the proper Galvanic connections of unusual windings are the key together with correct sequence of excitations ????
Сергей В.
People on Realstrannik forum were found Inverter which Akula used in his newest video.
Spezvision PSU-12-10M
http://donkordon.ru/product/psu-12-10m
Блок питания импульсный PSU-12-10M производства компании «Spezvision»предназначен для питания пониженным (безопасным) постоянным напряжением 12В устройств в составе охранных комплексов и систем видеонаблюдения, а также для других потребителей низкого напряжения, например: паяльники, светильники и др.
Характеристики:
Тип корпуса :Металл
Исполнение источника :IP 20
Входное напряжение :170/ 264 АС
Выходное напряжение :12В
Ток :10А
It's impulse PSU from Russian company Spezvision PSU-12-10M. Input voltage 170-264V, Output 12V 10A.
zcsaba77
Quote from: Сергей В. on May 21, 2013, 02:37:28 AM
Hi Sergej
May I ask TL494 generator is which part all stuff? Or is different generator?
Regards Zcsaba77
Hoppy
Quote from: Сергей В. on May 21, 2013, 03:22:35 AM
Характеристики:
Тип корпуса :Металл
Ток :10А
Where does he get the mains supply from to supply this 170/264V AC, 12V / 10A PSU?
Откуда у него сеть от поставлять эту 170/264V AC, 12V / 10A PSU?
OK, lets assume he has an incoming 230V supply from the grid or from a battery via an inverter. This then powers a Royer type oscillator from the 12V/10A PSU output, which in turn drives a transformer as shown below. The resulting HV/HF in the 50T secondary winding is 'mixed' with the same 230V mains to produce enough power to light the lamp array - shown as 6KW on the schematic! Question - is this a true 6KW or a complex waveform that in some way appears to drive the lamps brightly enough to pass as a high power output?? The output on this schematic is presumably simplified as no tuning caps are shown?
