0 Members and 114 Guests are viewing this topic.
Cap-Z-ro
Quote from
" A lot of calamities and bloodshed were prepared for all, except for... the Israelites. Through the Torah the God Jehovah promises them the moon, the enslavement of all the others and physical elimination of all "inconvenient" people! "
Those words of the torah were composed for no no other purpose than to divide and keep humanity in a constant state of chaos and distraction.
This was in all likelihood done in ancient times by an advanced race of deranged manipulators.
Regards...
zcsaba77
Quote from: Сергей В. on May 21, 2013, 05:38:56 AM
to Zcsaba77
TL494 is different generator. Use him instead IR2153. You can use any generator with independent tuning of Cкважность (can't be translated - no english word for this) and frequency like on sch. below
Cкважность is a ratio of pulse period to pulse duration. Or reciprocity of duty cycle. S=1/D t.e. T/τ .
If you want real good Signal Generator for experiments make this one on MAX038 with Sweep function and Frequency Markers on your oscillograph. All informations you can find here:
http://cappels.org/dproj/functsweep/functionswp.html
Hi Sergej
Can answer how much these freq. generators consumtion in amps, better says how much input? or COP?
regards Zcsaba77
br549
Wesley: I have watched your Colman Experiment with great interest. Really good stuff. I have a question about the RF frequency used. Was there a particular reason for the selected frequency, or was it just the availability of the transmitter? Thank You:
stivep
Quote from: br549 on May 21, 2013, 06:29:35 PM
the frequency of Colman from patent is 300Mhz
I have had no transmitter of this frequency at that particular time.
Right now I have 100 to 500 range  pf approx 100W/// The  problem is that The generator driving Amplifier is Sinus or sinus  pulse or AM modulation  sweep/// Do not know as of yet .... got to get  to manual
model :HP3200B
the Israeli 100-500 MHZ amplifier.
model: XRF 694 made for secret military encryption devices.
tank circuit:MFJ-923 it works  somehow in 100-500Mhz region.
50 Ohm dummy load just in case I want to check first general running ability ( response) of tank.
So what is wrong with that all?
Well i do not know as of yet.
I know however that  previous signal transmitted to Colman compound was 10-15 ........say max 20W from Kenwood  TS-2000 at 70cm  but using FM modulation pulsed by mike... that would be close enough to name it to CW carrier ( continuous wave)............. as there was no modulation as I was not talking to microphone most of the times it was than CW per say...
That let me establish that  Yoke is analogues to Colman  ... only in different form..
By that token We may assume that  Akula or TK operates  at the same principals.
Well...... assume hm..........
"everything says that the weather is exactly as prognoses made by Arunas, Verpies,Tiger .......  Wesley  as well.."
On the pictures - the dummy load will be replaced with   Colman coil+ capacitor acting as a load.
Wesley
Ganzha
Акула - посредник! Он слишком молод и выглядит как Мачо, кто-то ему видео по порциям выдал, он их показал а потом денег попросил. Изобретатель - не он!. Акула - молодой а голос на видео - пожилого человека!
