0 Members and 316 Guests are viewing this topic.
bolt
Quote from: scorpio on June 07, 2010, 04:32:36 AM
@FreeEnergyInfo
OK, I missed the surge protectors, but not essential.
Surge protectors is laymen term they are GDT's  glass discharge tubes and YES they ARE essential because they are 250 volt GDT's and prevent the light bulbs going over voltage and blowing!
So far this is a "proof of concept" device and he makes no claims about OU at this time only showing that the ground kapandze method can work. It needs a LOT more refinement before this can be looped and lot more tuning with careful selection of caps and coils to tune device into load.
It also needs at least TWO or THREE more stages because there is too much load on the spark gap primary. When this is running correctly the spark gap should operate at much higher voltage, higher frequency and very little current to give a faint blue corona "fizz".  Its pretty obvious right now the primary spark is drawing a LOT of power up to 1000 watts which i would expect as each stage only has a COP around 5 at best more like 2 if untuned.
To do this properly needs stage 1 neon supply or FET switcher to give 6Kv 25khz gain 5
stage 2    6kv upto  25kv increase frequency to around 1 meg gain 5 (volts up more joules)
stage 3   second spark gap 25kv to 10kv shift frequency 500hz gain 5
stage 4 10kv to ground induction 500hz to 50Hz/60Hz  requires about 3 to 5 microwave oven caps across coil to set the frequency.  Gain 5
now we have gain 5 * 5 * 5 * 5 = > COP 625
A FET HF 50 watts oscillator drive becomes 50 * 625 = 31,250 watts so even if you screw up real bad on tuning its not so hard to get 10KW in practice. OR  driver becomes a mere 5 watts with 3.1kw o/p now looping is a no brainer.
Still this is a step in the right direction because Naudin will hopefully make full disclosure not there was ever much to disclose it has been known for 100 years!
baroutologos
@Bolt,
you talk with great confidence. If you could prove the 1% of what you say then you are real genius man.
There is some new text on his page.
Quote from: jnaudinDue to the presence of High Voltage and the High Power output of the Kapagen, the electronic diagram is not published here because of the use of lethal High Voltage.
hmmmm.
gauschor
You must quote the whole text:
QuoteDue to the presence of High Voltage and the High Power output of the Kapagen, the electronic diagram is not published here because of the use of lethal High Voltage. User of this document should be very carefull and experienced in High-Voltage electronics to try anything out ! If you do it the risk of any results is just yours. I take no responsibility of anything that might happen
So he says it's everyone his own risk experimenting anyways and he does not take responsibility. Ok, good. Therefore he will not post the circuit. But then he claims users should be careful with "this document". Which document is he talking about???
A video clip with a blue box, bulbs and a coil with some spare notes is not a document. It does not even clear up, nor prove anything at all. We don't even know *what exactly* he has build or "replicated". Just because it looks like a Kapanadze-Device does not mean it is one. And what about the power source? No word about that... ridiculous...
Besides, this is exactly the kind of "documentation" I don't like in many of JLN "replications".
bolt
"Due to the presence of High Voltage and the High Power output of the Kapagen, the electronic diagram is not published here because of the use of lethal High Voltage. "
LOL now that is funny! ...back to the dark ages then.
Well i guess 95% of you wont try to work it out even though its been published over and over. That said using a MOT is deadly and unnecessary to give the initial high voltage. Better to use a neon supply and build up the required stages as Don Smith designs you dont even need a spark gap which are noisy. A GDT is silent and cleaner as Don Smith only used spark plug in his earliest design and all later systems used GDT's.
