0 Members and 469 Guests are viewing this topic.
scorpio
Quote from: bolt on June 07, 2010, 06:05:06 AM
Surge protectors is laymen term they are GDT's  glass discharge tubes and YES they ARE essential because they are 250 volt GDT's and prevent the light bulbs going over voltage and blowing!
So far this is a "proof of concept" device and he makes no claims about OU at this time only showing that the ground kapandze method can work. It needs a LOT more refinement before this can be looped and lot more tuning with careful selection of caps and coils to tune device into load.
It also needs at least TWO or THREE more stages because there is too much load on the spark gap primary. When this is running correctly the spark gap should operate at much higher voltage, higher frequency and very little current to give a faint blue corona "fizz".  Its pretty obvious right now the primary spark is drawing a LOT of power up to 1000 watts which i would expect as each stage only has a COP around 5 at best more like 2 if untuned.
To do this properly needs stage 1 neon supply or FET switcher to give 6Kv 25khz gain 5
stage 2    6kv upto  25kv increase frequency to around 1 meg gain 5 (volts up more joules)
stage 3   second spark gap 25kv to 10kv shift frequency 500hz gain 5
stage 4 10kv to ground induction 500hz to 50Hz/60Hz  requires about 3 to 5 microwave oven caps across coil to set the frequency.  Gain 5
now we have gain 5 * 5 * 5 * 5 = > COP 625
A FET HF 50 watts oscillator drive becomes 50 * 625 = 31,250 watts so even if you screw up real bad on tuning its not so hard to get 10KW in practice. OR  driver becomes a mere 5 watts with 3.1kw o/p now looping is a no brainer.
Still this is a step in the right direction because Naudin will hopefully make full disclosure not there was ever much to disclose it has been known for 100 years!
So even distribution of voltage. Maybe.
haithar
Unfortunately he did what he always does.  Putting together some photos and videos of an attempted replication, but being vague with the results, for example instead of measuring output vs. input energy he just shows the 230W input and also some barely lit 2300W nominal power lamps as the output.
Then he adds some random effect which could be used in the device and spices it with a warning about HV so he won't have to release more details, people go crazy but in the end he hasn't shown anything substantial.
scorpio
FreeEnergyInfo
bolt
He has shown a lot already and its clear that exciting the displacement ground currents can work through a very simple coil which has been reduced closer to the required 240 volts by using 5 turns overlay.
The i/p versus o/p is not so important at this time as proof of concept.
It also proves that the ground acts as a capacitor of some fairly large unknown value and the wider the spacing and thicker the earth wire the more current is available. This is because the distance between the 2 earth points takes a "sample" of the ELF ground currents of which the wavelengths is a many thousand miles long. o/p coil = L + (R resistance of ground wire) + C ground = f. So add more C to reduce f to 50/60Hz. Jaundin has no additional cap right now on his coil so the lights could be running at several hundred hertz or higher.
People often say well i measure only 2 volts 40 milliamps between my 2 metal ground rods how can there be REAL current. EASY when you measure something you measure ONLY the difference between the 2 points. If i sit on a power line and measure 2ft to my left with one probe then 2ft to my right with the other probe i will see maybe 3 volts on my meter yet im sat on a 125kv power line! What happens if i create a disturbance on that line using a capacitor, resistor, inductor etc i create a PD now my meter will see thousands of volts depending on the type of disruption created.
One earth can work but requires higher frequency operation as then the "capacitor" becomes the difference between the earth and the "sky".  Wavelength is now 100's of metres.  For no ground operation VHF operation is required so the difference as a potential becomes  a "virtual" earth on one side and a PD on the other side like the TPU. Wavelength is now 10's of metres. Higher frequency = more joules (voltage) pumped per second.
Still higher frequency operation is electrostatic flat air capacitor made using sheets of  aluminum and copper and acetate dielectric using casimir effect where operating frequency is UHF with harmonics to several gigahertz. Wavelength is now millimeters as PD operates between the Plates of the capacitor.
The smaller the plate gap the higher the frequency and operating voltage while the size of the plates exposes more area to the etheric frequencies which increases the farads or CHARGE at a risk of dielectric break down the more joules are available.  This is THE most POWERFUL system as shown by Don Smith Dipole.
Tesla showed a simple sheet capacitor which is earthed on one side and antenna the other. This passive cap will acquire a charge to be built up on the plates albeit not powerful.
Operation is basically the same. Disturbance of the ambiance will reply with GAIN.
