0 Members and 127 Guests are viewing this topic.
T-1000
Quote from: a.king21 on June 02, 2013, 07:27:32 AM
ElementSix: Do you have a link for your Tesla testimony?
http://www.tuks.nl/pdf/Reference_Material/Tesla/Collection%20of%20articles%20by%20Nikola%20Tesla.pdf
P.S> I think you should really see this implementation on Tesla toroidal generator and what is effect when coils are dead short or loaded: http://youtu.be/Zu4pzvkSkzo?t=12m10s
Zeitmaschine
Quote from: elementSix on June 02, 2013, 12:41:30 AM
First, a comparatively low frequency, which will reduce the radiation of the electromagnetic waves to a comparatively small value, and second, a great resonant effect.
I take a very large self-inductance and a comparatively small capacity, which I have constructed in a certain way so that the electricity cannot leak out.
I do not permit the energy to go out;
I am not producing radiation with my system; I am suppressing electromagnetic waves. . . . In my system, you should free yourself of the idea that there is radiation, that the energy is radiated.  It is not radiated; it is conserved.
Sounds like shielding by means of a Faraday cage (tin can) would be a good idea so that the electricity cannot leak out. 8)
Shokac
Quote from: leo48 on June 02, 2013, 06:36:05 AM
With google translate  ;D
  вход = input
  тариел капанадзе генератор = Tariel Kapanadze Generator
  изход = exit
Leo48
PAGE!
http://kapagen.livejournal.com/843.html?mode=reply
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
sparks
This coil, which I have subsequently shown in my patents Nos. 645,576 and 649,621, in the form of a spiral, was, as you see, [earlier] in the form of a cone.  The idea was to put the coil, with reference to the primary, in an inductive connection which was not close�we call it now a loose coupling�but free to permit a great resonant rise.  That was the first single step, as I say, toward the evolution of an invention which I have called my "magnifying transmitter." That means, a circuit connected to ground and to the antenna, of a tremendous electromagnetic momentum and small damping factor, with all the conditions so determined that an immense accumulation of electrical energy can take place.
It was along this line that I finally arrived at the results described in my article in the Century Magazine of June 1900.  [Fig. 43] shows an alternator; not the alternator that was furnished for my laboratory on Houston Street�that was another one, [but] at 35 South Fifth Avenue [and] operated on the same principle.  Here [lower left] are the condensers, primary, and all the rest.  The discharge there was 5 or 6 feet, comparatively small to what I subsequently obtained.  I have produced discharges of 100 feet, and could produce some of 1,000 feet if necessary, with the greatest facility.
Counsel
Mr. Tesla, at that point, what did you mean by electro-magnetic momentum?
Tesla
I mean that you have to have in the circuit, inertia. You have to have a large self-inductance in order that you may accomplish two things: First, a comparatively low frequency, which will reduce the radiation of the electromagnetic waves to a comparatively small value, and second, a great resonant effect.  That is not possible in an antenna, for instance, of large capacity and small self-inductance.  A large capacity and small self-inductance is the poorest kind of circuit which can be constructed; it gives a very small resonant effect.  That was the reason why in my experiments in Colorado the energies were 1,000 times greater than in the present antennae.
Counsel
You say the energy was 1,000 times greater.  Do you mean that the voltage was increased, or the current, or both?
Tesla
Yes [both].  To be more explicit, I take a very large self-inductance and a comparatively small capacity, which I have constructed in a certain way so that the electricity cannot leak out.  I thus obtain a low frequency; but, as you know, the electromagnetic radiation is proportionate to the square root of the capacity divided by the self-induction.  I do not permit the energy to go out; I accumulate in that circuit a tremendous energy.  When the high potential is attained, if I want to give off electromagnetic waves, I do so, but I prefer to reduce those waves in quantity and pass a current into the earth, because electromagnetic wave energy is not recoverable while that [earth] current is entirely recoverable, being the energy stored in an elastic system.
Counsel
What elastic system do you refer to?
Tesla
I mean this: If you pass a current into a circuit with large self-induction, and no radiation takes place, and you have a low resistance, there is no possibility of this energy getting out into space; therefore, the impressed impulses accumulate.
Counsel
Let's see if I understand this correctly.  If you have radiation or electromagnetic waves going from your system, the energy is wasted?
Tesla
Absolutely wasted.  From my circuit you can get either electromagnetic waves, 90 percent of electromagnetic waves if you like, and 10 percent in the current energy that passes through the earth.  Or, you can reverse the process and get 10 percent of the energy in electromagnetic waves and 90 percent in energy of the current that passes through the earth.
It is just like this: I have invented a knife.  The knife can cut with the sharp edge.  I tell the man who applies my invention, you must cut with the sharp edge.  I know perfectly well you can cut butter with the blunt edge, but my knife is not intended for this.  You must not make the antenna give off 90 percent in electromagnetic and 10 percent in current waves, because the electromagnetic waves are lost by the time you are a few arcs around the planet, while the current travels to the uttermost distance of the globe and can be recovered.
This view, by the way, is now confirmed.  Note, for instance, the mathematical treatise of Sommerfeld,
  • who shows that my theory is correct, that I was right in my explanations of the phenomena, and that the profession was completely misled.  This is the reason why these followers of mine in high frequency currents have made a mistake.  They wanted to make high frequency alternators of 200,000 cycles with the idea that they would produce electromagnetic waves, 90 percent in electromagnetic waves and the rest in current energy.  I only used low alternations, and I produced 90 percent in current energy and only 10 percent in electromagnetic waves, which are wasted, and that is why I got my results. . . .
    You see, the apparatus which I have devised was an apparatus enabling one to produce tremendous differences of potential and currents in an antenna circuit.  These requirements must be fulfilled, whether you transmit by currents of conduction, or whether you transmit by electromagnetic waves.  You want high potential currents, you want a great amount of vibratory energy; but you can graduate this vibratory energy.  By proper design and choice of wave lengths, you can arrange it so that you get, for instance, 5 percent in these electromagnetic waves and 95 percent in the current that goes through the earth.  That is what I am doing.  Or you can get, as these radio men, 95 percent in the energy of electromagnetic waves and only 5 percent in the energy of the current. . . . The apparatus is suitable for one or the other method.  I am not producing radiation with my system; I am suppressing electromagnetic waves. . . . In my system, you should free yourself of the idea that there is radiation, that the energy is radiated.  It is not radiated; it is conserved.
And this is how he did it.
http://www.allaboutcircuits.com/vol_2/chpt_14/6.html
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
